How to measure the scale length of a guitar? - Jemsite
post #1 of 4 (permalink) Old 09-23-2002, 08:47 PM Thread Starter
eg
I'd just like to know how is scale length of a guitar is measured
eg is offline
post #2 of 4 (permalink) Old 09-23-2002, 09:18 PM
To measure scale length, just measure from the nut to the middle of the 12th fret, then double it.
If you mean actually calculating scale length and all the fret distances, you need to do a lot of math and geometry. (Pythagorean theorem, mostly.)
Or, you can use a simplified method, described here.
darren wilson is offline
post #3 of 4 (permalink) Old 09-23-2002, 09:54 PM Thread Starter
eg
Thanks. I was more interested in measuring not calculating
eg is offline
post #4 of 4 (permalink) Old 09-23-2002, 11:33 PM
Darren is right on the money!
If you did need a fret calculator though you can use this one which will save you time and trouble.
If you simply want to know what the scale is of a particular guitar is without doing any math, just measure the distance from where the string leave's the nut to where it touches the bridge.
In most case's your only going to find the following scales.
25.5" scale found on almost every modern day bolt on strat style neck.
24.75" scale found mostly on Gibson necks.
25.4" scale found mostly on Martin acoustics.
25" scale found mostly on PRS
Project Guitar is offline
strat style
Human Verification
How do you measure a scale length ? edo JEM and Universe Guitars 18 03-24-2013 07:09 PM
Guitar Neck Scale length question 2DECADESSOFAR Gear and Equipment 14 08-10-2012 06:27 PM
Actual scale length? measure from nut to centre of studs? MorbidAngel Tech: Setup, Repairs and Mods 1 12-28-2003 07:40 PM
Ibanez AF 207 7 string jazzer-24.7"scale?? - Scale length is speedball Comments to Ibanez 12 01-12-2003 09:44 PM
How do you like the XL scale length? Zeek Other 7-string Guitars 22 11-13-2002 11:02 AM
