Old 07-28-2006, 11:58 AM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
How much tung oil is enough / too much?
Im asking about necks... Ive done a few by now, and always liked the results, usually do 5, or 6 coats... but the thing is, i always prefer the feel of raw wood better!
The problem is, i dont want to leave it raw cause of sweat, dirt, in case something bad happens (water or whatever)...
what do you guys do?
Old 07-28-2006, 02:41 PM
frankfalbo  is offline
Re: How much tung oil is enough / too much?
If you want it to remain cleanable for cosmetic reasons, you need 4-5 coats, or a polymerized finish. The tung oil finish has to kind of fill the grains for that to happen. Otherwise the dark "soylent green" will get into the fibers and grains. You'd be able to clean the surface, but you'd still have dark grains. I don't get my guitars dirty, though (or whatever reason) so I prefer 1-2 coats of tung oil. That's enough for protection against the elements in my opinion. When I want a thicker finish I don't use tung oil. I use a polymerized tung oil finish, that's roughly 80% tung oil with hardeners. That way I can build it and I know it'll get hard in the pores quickly. Subsequent coats build more of a "skin" over the wood instead of soaking into the fibers.
Old 07-28-2006, 02:43 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Use Fret Doctor!
Old 07-28-2006, 02:58 PM
Cool, ill leave this one at two coats... see how it i like it... if the worse should happen, i can always sand a lil and add a couple more coats later on
Thanx Frank
Old 07-28-2006, 04:55 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Originally Posted by Deeswift
Use Fret Doctor!
Fret doctor wont do anything to protect the color of an unfinished neck dee.
Old 07-28-2006, 05:26 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
Ive never oiled a guitar but ive made plenty of wooden furniture, most of the time I use danish oil (dont try that on yer guitars folks) and 2 coats is enough for full protection, after that your just filling in the grain of the wood and achiveing a glass like finish.
Frankfalbo is right IMO - 2 coats is all you need I would rub it down between coats too with a really light wire wool.
Old 07-28-2006, 05:42 PM
Dee  is offline
It works fine on mine!
Old 07-28-2006, 06:12 PM
ITs not a finishing product dee thus it wont actually stop grime from working into the wood grain.
Old 07-28-2006, 06:34 PM
King Nothing  is offline
Posts: 333  -  iTrader: (1)
I always wondered why my buddy's neck turned dark green on the back behind the first few frets. I guess that's LTD for you!
Old 07-28-2006, 07:03 PM
ChopTart  is offline
Posts: 1,390  -  iTrader: (1)
When you can squeeze your neck and tung oil wrings out...its too much
Old 07-28-2006, 07:16 PM
Ah yes, but when you squeeze your neck after a gig and sweat wrings out, it means you didn't use enough!
Old 07-28-2006, 07:50 PM
Dee  is offline
OK Sniper.
Old 07-29-2006, 03:54 AM
OK Sniper.
Awww you sound so sad. It will condition the fretboard rather nicely though
Old 07-29-2006, 04:28 AM
Dee  is offline
tung oil
Tung Oil or Danish Oil? Steve_Vai_777 Tech: Setup, Repairs and Mods 4 09-06-2005 06:05 PM
how dark is tung oil? phil0333 Tech: Setup, Repairs and Mods 4 03-13-2005 12:41 AM
Tung oil hardening Shredd Tech: Setup, Repairs and Mods 7 05-19-2003 02:55 PM
Tung Oil Curing Time? Drew Tech: Setup, Repairs and Mods 12 04-03-2003 01:47 AM
Tung oil/Teak oil refinish question... Jupiter Tech: Setup, Repairs and Mods 15 10-04-2002 05:45 PM
