Old 03-06-2003, 04:53 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
How to make a mirror pickguard
I was wondering if anyone can help me on how to make a black mirror pickguard fit for a UV.
Reg
Old 03-06-2003, 05:13 PM
EKG  is offline
Posts: 2,280  -  iTrader: (0)
Do you have an original UV guard to go from?
You need:
1 Original or template
New material
Router
Drill
Countersink
Spacers and screws to offset new material from template
Old 03-06-2003, 07:05 PM
reguv760  is offline
Images: 5
Reviews: 12
Yep... I'll just have to pry it out from my GR...
New material
Router
Drill
Countersink
Well... I was considering using acrylic over a black mirror. I have the acrylic but where do i get a black mirror? I have a dremel with routing bits and a drill so I think I'll do fine with those tools and an x-acto knife
Reg
Old 03-06-2003, 07:48 PM
EKG  is offline
Try www.allparts.com for a wide variety of materials. They have the mirrored stuff, I think
Old 03-07-2003, 07:38 PM
musicdr  is offline
Posts: 671  -  iTrader: (0)
I just tried routing acrylic with a dremel on its lowest speed,it melts.Instead I used a scroll saw at its lowest speed with good results.It definitely requires some patience.
Old 03-07-2003, 07:43 PM
EKG  is offline
Even a scroll will melt your material....as you cut, the cut you just made melts back together behind the blade.
A table router would be best (hint :-) )
Old 03-08-2003, 09:01 PM
musicdr  is offline
Hi eddie I'm using a table top scroll saw(variable speed) with a speed of 400.It doesn't melt the acrylic.In fact it works really good.I'll agree that any speed faster will melt your cuts back together.What speed are you using with your router?It is definitely a bit of work that goes into a pickguard.
