Old 09-23-2002, 09:47 PM
eg  is offline
Posts: 259  -  iTrader: (0)
How to measure the scale length of a guitar?
I'd just like to know how is scale length of a guitar is measured
Old 09-23-2002, 10:18 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
To measure scale length, just measure from the nut to the middle of the 12th fret, then double it.
If you mean actually calculating scale length and all the fret distances, you need to do a lot of math and geometry. (Pythagorean theorem, mostly.)
Or, you can use a simplified method, described here.
Old 09-23-2002, 10:54 PM
eg  is offline
Thanks. I was more interested in measuring not calculating
Old 09-24-2002, 12:33 AM
Project Guitar  is offline
Posts: 979  -  iTrader: (0)
Darren is right on the money!
If you did need a fret calculator though you can use this one which will save you time and trouble.
If you simply want to know what the scale is of a particular guitar is without doing any math, just measure the distance from where the string leave's the nut to where it touches the bridge.
In most case's your only going to find the following scales.
25.5" scale found on almost every modern day bolt on strat style neck.
24.75" scale found mostly on Gibson necks.
25.4" scale found mostly on Martin acoustics.
25" scale found mostly on PRS
strat style
