Tech: Setup, Repairs and Mods
How to treat Ebony Fingerboard
11-11-2006, 03:17 PM
Kemono
Posts: 157 - iTrader: (
My 8670 is kind of sticky on the fingerboard. How can I clean and treat it?
Dunno what the stickiness is. Sweat, grime, "guitar honey", or ???
Point is: I want to clean and treat the
Ebony fingerboard
. How do I do it?
Kemono
Visit Kemono's homepage!
Find all posts by Kemono
11-11-2006, 04:22 PM
Jempy(HoTrOd)
INACTIVE USER
Posts: 93 - iTrader: (
Re: How to treat Ebony Fingerboard
Just read the tech from Rich:
http://www.ibanezrules.com/tech/grunge/grunge_1.htm
Pretty much everything you want to know is there
Jempy(HoTrOd)
Find all posts by Jempy(HoTrOd)
11-11-2006, 09:12 PM
Kemono
That's a great tutorial but the guitar has a
rosewood board
I can't do those guitar pick or fingernail scrapes on ebony. Ebony is pretty soft and scratches really easily. I already have some scratches.
The tutorial uses 0000 steel wool right on the board. Is it OK to use the 0000 steel wool on an
Ebony board
Next on the tutorial, there's the use of oil.
Should I use bore oil? I bought some but then I noticed that it was just mineral oil and mineral oil is supposed to be pretty bad for the wood.
Should I get lemon oil? Is Jasco a good brand?
But boredoctor says that oils which contain petroleum are bad (Jasco lemon oil does, I think).
It is an interesting read -->
http://www.beafifer.com/boredoctor.htm
Kemono
11-11-2006, 09:29 PM
IbanezGirl
Posts: 996 - iTrader: (
I wouldn't recommend using Lemon Oil. It is well known for drying out woods.
I don't have an
ebony fretboard
so i cannot say what's the best to use for that wood. I'm sure a member here will be able to help you out though.
On my rosewood board i do use Bore Oil - some places call it Fretdoctor?? (same thing) and it works a treat. It's also been recommended to me to use Lindseed Oil, which i haven't tried. I guess you could do a goggle search on the Linseed and ebony and see what comes up
IbanezGirl
Find all posts by IbanezGirl
11-11-2006, 10:54 PM
Posts: 19,352 - iTrader: (
Ebony is harder than rosewood.
If you like Fretdoctor order that, otherwise any GOOD quality bore oil is fine.
Never use lindseed oil, it's equivalent to a varnish like
tung oil
11-11-2006, 11:22 PM
Lefty Robb
Posts: 4,930 - iTrader: (
Kemono
That's a great tutorial but the guitar has a rosewood board.
You sure its Ebony then?
Lefty Robb
Find all posts by Lefty Robb
11-12-2006, 03:34 AM
Kemono
Oh, I assumed that rosewood would be harder. I was wrong.
I got some very small indentations on the fingerboard while cleaning it with a rag, using my thumbnail. I stopped that as soon as I noticed that what I was doing was causing indentations. If rosewood scratches easier than that, I guess you have to be *really* careful.
I'll stay away from linseed, tung, any petroleum-based, or mineral oil. IbanezGirl, you are lucky you didn't try linseed oil! Thanks, Rich, for saying not to use that.
"Tha plan" includes:
* 0000
Steel wool
* fretdoctor
* Rich's pinching technique
* follow the golden rule: Go with the grain.
Kemono
11-12-2006, 03:39 AM
IbanezGirl
So true, Kemono. The sad thing is, the guys at Ibanez here in OZ recommended the Linseed Oil
but luckily i went with Rich's choice instead
IbanezGirl
11-12-2006, 05:54 PM
ryanb
Posts: 1,457 - iTrader: (
Pure linseed oil will basically never dry and will be a sticky mess forever. Boiled linseed oil is like tung oil, and will dry after a while, but can be a pain to use. Lemon oil just dries out the wood. Just stick with the bore oil -- it's cheap, simple, and effective.
ryanb
Find all posts by ryanb
11-14-2006, 02:20 AM
frankfalbo
Posts: 1,875 - iTrader: (
Boiled linseed is also too thick to penetrate Ebony. It'll just rest on the surface.
I can't believe you're denting Ebony from cleaning or rubbing. You're either scratching the top layer of grime, or you think that the slight change in the surface shine is actually a scratch. Ebony is one of the hardest woods available, and will withstand a tremendous amount of abuse.
frankfalbo
Find all posts by frankfalbo
11-14-2006, 04:34 PM
CrossingStar
Posts: 1,046 - iTrader: (
What I've discovered from searching for answers on what oil to use is that -- there is no answer. Everybody has a different opinion and I do mean
opinion
on what to use. Often conflicting ones.
CrossingStar
Find all posts by CrossingStar
11-17-2006, 07:30 AM
GTR-MAN
Posts: 1,056 - iTrader: (
BORE OIL !!! lemon oil will not only dry out faster, it contains citric acid and will help corode your frets and any other metal it touches. Even the good guys at Martin post this in their "how to care for your guitar" section.
BORE OIL is the best.
GTR-MAN
Find all posts by GTR-MAN
11-21-2006, 10:04 PM
madpickin03
Posts: 531 - iTrader: (
I use bore oil, and lighter fluid + soft tootbrush to get through the grains.
madpickin03
Visit madpickin03's homepage!
Find all posts by madpickin03
ebony board
ebony fingerboard
ebony fretboard
rosewood board
steel wool
tung oil
what oil should i use fingerboard ibanez jem
how to dye a ebony fretboard
how much does it cost to scallop a fingerboard
ibanez 3120 with ebony fingerboar?
how to narrow the fingerboard without removing it
Tell us about you guitar setup/rig Everyone!!!
GuitarWizard
Gear and Equipment
606
02-01-2012
09:03 PM
Whats everyone play?
Thrash
193
02-11-2007
10:08 AM
How much money have you spent?
Koss
Gear and Equipment
122
02-08-2006
09:27 PM
How can you tell if ebony is damaged?
Black Star
12:05 AM
Ebony Fingerboard?
johliatay
10:03 AM
11:06 PM
