That sounds like a ground loop problem. I sometimes had the same problem when plugging my Parker into an amp and PA simultaneously, especially when going out of the XLR output on my direct box into the board. For some reason, the regular 1/4" output didn't have that problem.
It helps to have all of your gear plugged into the same outlet. If any of your gear uses two-prong electrical plugs, try reversing the plugs in the outlets to switch polarity.
Try everything Kevan suggested, too.
