Closed Thread
Old 02-20-2007, 10:15 PM
AmazinAzian12  is offline
Posts: 549  -  iTrader: (0)
Unhappy
I am so mad at my Jem!!!!
Ok. Yes Im stupid. You can all flame this thread.
I just got new strings. Blue Steels. 9-42's. I just installed them now.
When all the strings were on, i notice a lot of buzz coming from my Low E and A strings. All up the fretboard. It wont stop!!!!
And worse than that. When i get the angle of the bridge perfect, i pull up on the trem and it doesnt return to the perfect angle.
Now i really wanna just throw my jem into a mulcher!
Please. I read the Action height section and the truss rod section. I get what action is. But what is relief??? My neck i perfectly straight. How do i put relief on the neck? is relief loosening the truss rod so that the neck goes concave??
Please Please Please. I have to play in my Jazz band and Hilary Clinton will be watching tomorrow. I need help!!! I cant bring my guitar to a tech. I have no time to get someone else to fix it for me. This cant be a hard thing to fix. My other guitar is at a shop getting a fernandes sustainer installed and wont be done until friday.
Lets recap:
1)Fret Buzz, what is relief, and how to get no fret buzz. Trem is at perfect height.
2)Tremolo when doing dive bombs and pull ups wont return to neutral. Is there anything to help the trem to return to neutral.
Anyone that knows how to fix the above problems, like a tech like Rich or anyone who has knowledge in the above, please!!
Old 02-20-2007, 10:19 PM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: I am so mad at my Jem!!!!
I'm not touching this one.
Old 02-20-2007, 10:21 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Serves you right for buying Blue Steels
Old 02-20-2007, 10:23 PM
Same problem when i had GHS strings
Old 02-20-2007, 10:25 PM
elcid  is offline
Then why didnt you get it fixed back then?
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Relief: Simply put as possible, your neck should bend back just a tiny bit in the middle to avoid fret buzz. Your neck may be too straight. Try loosening the truss rod just a small amount, leave it to settle for a while, then see if has any effect. Make a mental note of how far your turn the rod. Go in small steps here, like a quarter of a turn or less.
How far out is the trem after dive or pull-up?
Old 02-20-2007, 10:26 PM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
LOL, ok although Blue Steels suck.....loosen the truss rod about a Quarter of a turn; turn from bass side to treble
Old 02-20-2007, 10:28 PM
crevis  is offline
raise the action a tad.
Old 02-20-2007, 10:30 PM
Dee  is offline
Yeah, or raise the action slightly. I presume you tried this already though, Azian?
Did you read Rich's guides?
Old 02-20-2007, 10:34 PM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Alright, I'm going to be a charitable soul and try to help you out.
First, you need to get past the emotional aspect of these problems. Being mad at your Jem is silly. Don't expect that just because it cost a lot of money it won't have the same problems a guitar 1/4 the cost will.
Second, deal with the BIG problem and that's the fret buzz. The trem not returning to pitch secondary. You don't have to use your trem but if you can't get the guitar to play decently, then you won't want to play it.
If your neck is perfectly straight, then it needs a little relief or a little backbow. The strings are vibrating too much for the amount of space between them and the fret board. Once you get the relief dialed in (a 1/4 should be enough) then see if you're still getting fret buzz and where it might be. If you want low action then you're going to get some fret buzz. The question is how much and does it really come through when you're plugged into an amp?
Where did you buy your Jem?
Old 02-20-2007, 10:36 PM
toneboy  is offline
Have you read the manual that came with the Jem?
Old 02-20-2007, 10:41 PM
elcid  is offline
....and dont sweat it so much, Hilary Clinton wont really be watching, she'll just be there.
  #13
Old 02-20-2007, 10:42 PM
Rotti  is offline
Posts: 3,341  -  iTrader: (8)
I'm thinking "Chibanez" here. Could be wrong....
  #14
Old 02-20-2007, 10:45 PM
crevis  is offline
I'd like to see a chibanez BRMR
  #15
Old 02-20-2007, 10:49 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,042  -  iTrader: (9)
+1 on that...
Loosen your truss rod a hair, raise your action slightly. That should get you going.
Stretch the living crap out of your strings. Nothing will get you on your way to fixing a tuning instability issue like stretching the strings.
Closed Thread
bridge height adjustment, fernandes sustainer, floating trems, fret board, fret buzz, guitar tech, neck relief, signature guitar, trem studs, truss rod
Custom JEM vs Production JEM littlegreenman JEM and Universe Guitars 46 06-17-2008 03:14 AM
Jem story - happy ending screamndemon69 JEM and Universe Guitars 47 09-02-2005 11:45 AM
An Old JEM for an Older Guy - Luv those vintage Jems David Ho JEM and Universe Guitars 35 06-22-2005 12:29 PM
Got My New JEM 7VWH From Ibanez Rules Warrior JEM and Universe Guitars 11 03-15-2005 02:06 PM
Nice story to tell - How I've found a JEM 10 jember JEM and Universe Guitars 9 03-20-2002 06:22 PM
