Tech: Setup, Repairs and Mods
I decided to shield my guitar
07-26-2007, 07:13 PM
-Rhaab
Posts: 479 - iTrader: (
Im going to use tinfoil in the control cavity
is there any significant different in noise reduction from using tin foil compared to copper foil?
and is there any special kind of glue i should use?
-Rhaab
Find all posts by -Rhaab
07-26-2007, 08:37 PM
David McCarroll
Posts: 2,049 - iTrader: (
Re: I decided to shield my guitar
No real difference - in fact Aluminium is a better conductor than Copper - so why isn't it used for wire you ask?
Because you can't solder Aluminium - hence you will have to work out how to reliably ground your shielding - you don't ground it, it doesn't do anything!
David McCarroll
Find all posts by David McCarroll
07-27-2007, 06:20 AM
-Rhaab
im gona try glueing it all in one piece with a bit over the opening so the
cavity cover
can contact it too, and it will be all be grounded by the knobs.
-Rhaab
07-27-2007, 11:29 AM
Gusfmm
Posts: 280 - iTrader: (
Rhaab,
A question, why are you concerned trying to shield the electronics cavity? If you were to pickup electromagnetic noise from the surroundings, your guitar pickups are the first to "translate" that into your audio signal. So why bothering? Tiny pickup cables inside the cavity handle very low voltages, have very short runs, and follow quasi-random paths, so either external or self-inductance should not be a concern.
Besides, the moment you cover the whole deal with foil, you are gonna have a single big ground conductor for all the stuff in the cavity, so you better be careful there are no connections, cable ends, soldering points, or circuit terminals (in the rarer event you had a piezo), unprotected that may get in contact with that or your are gonna have an issue much worse than what you thought you had initially.
I'd personally recommend against doing that your doing.
Gus.
Gusfmm
Find all posts by Gusfmm
07-27-2007, 11:05 PM
Active 80's
Posts: 98 - iTrader: (
Gusfmm, if you were next to me i would yell at you. Many times my guitar teacher's guitar picked up random RADIO, and buzzing noises, in his custom (all hand made) non shielded guitar... and we are in a tiny cement/brick walled with sound proofing... yes radio... happened to be spanish...
it never occured all that long, but still... not somthing most would consider GOOOD...
Active 80's
Find all posts by Active 80's
07-27-2007, 11:43 PM
Gusfmm
If that happened to Vai, he'd probably use that as inspiration and turn it all into a shredding monster tune!
Gusfmm
07-28-2007, 12:03 AM
misplacedsanity
Suspended
Posts: 96 - iTrader: (
Reminds me of Spinal Tap at the airbase. Although I doubt your guitar teacher smashed his guitar to the floor stormed off and left the band.
misplacedsanity
Find all posts by misplacedsanity
07-28-2007, 10:32 PM
Active 80's
Gusfmm
LOL
quote (ghetto version of a quote) Reminds me of Spinal Tap at the airbase. Although I doubt your guitar teacher smashed his guitar to the floor stormed off and left the band.
end quote
LOL
no he didnt, i dont think he could afford that, its a very nice guitar... and if he did, i dont know if i would feel safe enough to show up to lessons any more
Active 80's
07-29-2007, 01:57 AM
Martyr Machine
Posts: 340 - iTrader: (
Gusfmm
I'm pretty sure that the strange sounds at the beginning of Satriani's
Flying in Blue Dream
were radio signals picked up by his guitar.
Martyr Machine
Find all posts by Martyr Machine
07-29-2007, 04:57 PM
Gusfmm
Martyr Machine
That's right, I'd forgotten about that one.
Jennifer Batten
has also got one suffering from the same issue, her version of Giant Steps, on the CD titled "ABOVE BELOW AND BEYOND"...
Gus.
Gusfmm
09-02-2007, 10:23 PM
Champagne Mist
Posts: 153 - iTrader: (
David McCarroll
Aluminum is not a better conductor than copper. Copper and silver are best, then gold. Gold is often used in place of copper (or silver) because it doesn't oxidize. Aluminum is indeed used as a conductor, when weight is a factor.
For truly effective shielding, you would use a ferro-magnetic material, but since no one wants to put a steel box in the electronics cavity, other conductors are fine. For the same thickness and permeabilities, the better conductor is the better shield. i.e. copper is better than tin.
10:32 PM
Champagne Mist
Find all posts by Champagne Mist
03-07-2011, 08:41 AM
raphaelnikolai
Posts: 1 - iTrader: (
check this post.. it might be helpful..
build-a-guitar.com/shielding-the-guitar-electronics/
raphaelnikolai
Find all posts by raphaelnikolai
03-07-2011, 11:02 AM
Hikey Mikey
Posts: 1,399 - iTrader: (
raphaelnikolai
Check the date of the post immediately preceding yours . . . might be even more helpful.
Peace
Mike
Hikey Mikey
Visit Hikey Mikey's homepage!
Find all posts by Hikey Mikey
03-07-2011, 07:37 PM
guitvai1
Posts: 471 - iTrader: (
The cheapest and easiest method I found was to go to Home Depot and get a big roll of aluminum duct sealing tape. Works great.
The only time I've heard radio come out of my amp was with a faulty cable.
guitvai1
Find all posts by guitvai1
03-07-2011, 07:49 PM
linuxpenguin
Posts: 3,467 - iTrader: (
Reviews: 11
David McCarroll
aluminum is
not
more conductive then copper.
for the thread, you can buy copper or silver (obviously silver is more pricey) shielding paint from a NON GUITAR store for "cheap". Little bit goes a LONG LONG way. Guitar oriented places jack the prices WAY up because its a niche market for us.
tin foil will work, but isnt the greatest; not to mention it looks super tacky. That tape would be the best "cost effective" solution.
Carbon would work as well
linuxpenguin
Find all posts by linuxpenguin
cavity cover
david mccarroll
jennifer batten
what guitar ibanez guitar is shawn lane using in his video
how do i fix a synsonics guitar?
what age guitar
how to swirl a guitar
how to lubricate guitar nut
Why is Steve Vai's Prototype DNA in a guitar store window? -
moochie777
02:39 AM
Funny guitar article
Dino
40
05-11-2007
09:24 PM
Photos of EVO.
Ibanez-Mag
10-31-2005
07:33 PM
guitar man with nothing but bad attitude
Joshka
Other 7-string Guitars
10:58 AM
How to transport a guitar to Jemfest for flyers. - Safety fi
Gabe Nickelson
Jemfest Forum
03:37 PM
04:55 PM
