Tech: Setup, Repairs and Mods
I have a question about nut cracks
08-19-2008, 11:08 PM
CosmicDebris
Posts: 3,216 - iTrader: (
Are older Ibanez necks that weak at the nut? It seems like a common thing on the guitars I see listed that many have this break and/or repair. The first
neck
I had on my 89 550 broke in that exact way but it was because my girlfriend and I at the time wern't paying attention to our surroundings and we fell on it while it sat on the bed.
Do they really
crack
like I have seen from normal playing and wammy use?
CosmicDebris
Find all posts by CosmicDebris
08-19-2008, 11:20 PM
jaxadam
Classified Watchdog
Posts: 3,043 - iTrader: (
Re: I have a question about nut cracks
I don't have an answer, but I have questions about other nut issues...
jaxadam
Find all posts by jaxadam
08-19-2008, 11:28 PM
CosmicDebris
jaxadam
It's right on the tip of your tounge........
CosmicDebris
08-20-2008, 01:54 PM
NiCkMiLnE
Posts: 75 - iTrader: (
the cracks happen through the allen bolts that clamp down, and the ones that hold the nut on being over tightened..or the headstock encountering trauma.
easy fix if its not broken off already...just take off the clamps, over tune it a little so the crack can open if its possible...get as much glue into the crack as you can (put a blob on the crack and "swipe" it in with a credit card.
keep doing this every few seconds with the glue till it wont let anymore in..then close the crack with clamps and allow to dry.
that should be a decent fix if your parranoid, but otherwise leave it.its safe!!
NiCkMiLnE
Find all posts by NiCkMiLnE
08-20-2008, 06:03 PM
CosmicDebris
Thanks for the reply nick but I guess you didn't read my
question
. I know how to fix it as I have fixed mine old one in the past.
Me
Do they really break from normal playing and wammy use>
CosmicDebris
08-21-2008, 09:19 PM
elcid
Posts: 8,720 - iTrader: (
Uh yeah, I have a question about nut sacks
elcid
Find all posts by elcid
08-21-2008, 09:32 PM
vaitamin7v
Posts: 40 - iTrader: (
certain ibanez necks are thin which would make them weak. depends on how you play and use trem. however I've never had any problems.
vaitamin7v
Find all posts by vaitamin7v
08-21-2008, 09:33 PM
NiCkMiLnE
read the first line of my reply.
yes they do through normal use, but only extended use over many years.
its uncommon without such a prompt as overtightening bolts or headstock trauma..but happens occasionally
NiCkMiLnE
08-21-2008, 10:10 PM
Posts: 19,352 - iTrader: (
Ass cracks are very common. My bet is, everybody has one. Cracks stink.
Nut cracks, are very uncommon. I love how every time you see one being sold it's always described as "common" to try and downplay the issue. Nut cracks devalue, a lot, no matter if they effect tuning and stability or not. But they are quite rare.
08-21-2008, 10:21 PM
CosmicDebris
Thanks alot Rich for answering my question and confirming what I thought.
CosmicDebris
08-21-2008, 10:56 PM
Racerx2k
Posts: 1,076 - iTrader: (
I had a nut crack, once, but, then again, it wouldn't have happened had I NOT stepped on that rake!
Racerx2k
Find all posts by Racerx2k
crack
neck
nuts
puppies
question
What causes cracks in a guitar at the joint
how to fix paint cracks on guitars
how to fix cracks in clear coat on guitar
QUESTION: what's the next number?? 1, 2, 6, 42, 1806, ? the 6th number is the password to the exce
What causes finish cracks?
jolly
01:24 PM
Neck Pocket Cracks?????
caruso1974
08:09 PM
Neck Pocket Cracks
ssguitarhero111
07:32 PM
Neck pocket cracks =\
JforJem
29
12-28-2006
09:30 PM
-URGENT- How do I tell cracks from scratches
IbanezroadstarII
03:35 AM
12:07 AM
