Tech: Setup, Repairs and Mods
I need help ?
09-30-2007, 04:53 PM
hollow125
Posts: 39 - iTrader: (
I need help ?
I know maybe this question was answered in other threads but my quick search didnt do any good so I'll tell you the problem
When I dive with my new Jem77VBK the G string goes flat most of the times ... making all other strings sharp a bit.
I have changed the strings on it ( yes I stretch them properly ) and I have tightened all the screws of the
locking nut
and of the neck.
I haven't seen any apparent trouble with the Edge pro...
What could it be
Hugo
hollow125
Find all posts by hollow125
09-30-2007, 05:03 PM
reguv760
Posts: 1,197 - iTrader: (
Reviews: 12
Re: I need help ?
is the saddle for the G-string (hehehe) properly intonated? as a matter of fact, is everything else intonated?
Reg
reguv760
Visit reguv760's homepage!
Find all posts by reguv760
09-30-2007, 05:07 PM
hollow125
Re: I need help ?
U mean the set screw that can make the saddle go back and forth ? Can it affect the tuning stability ? well I'll check it ...
hollow125
09-30-2007, 05:12 PM
hollow125
Re: I need help ?
Well right now as I speak the Intonation is from the Factory and the G-
string saddle
is completely towards the pick up, the others are in the middle and the Low E saddle sits completely at the back ... Wierd configuration ?
hollow125
09-30-2007, 05:17 PM
reguv760
Reviews: 12
Re: I need help ?
if the saddle is not intonated for that specific string, it can become unstable when doing dives. actually, if the saddles themselves are not intonated for the set of strings, it can have some effect to stability but it's a minor problem that can solved with an
allen wrench
and a damn good tuner
Well right now as I speak the Intonation is from the Factory and the G-string saddle is completely towards the pick up, the others are in the middle and the Low E saddle sits completely at the back ... Wierd configuration ?
not at all... but that sounds about right: thicker gauge = further away from the pickup; that's only for the Low E string.
Reg
reguv760
09-30-2007, 05:18 PM
Jaden
Posts: 2,464 - iTrader: (
Re: I need help ?
FWIW, what string brand are you using... ?
I always founf that the ernire ball G string was out... no matter what I did.
so I changed to daddarios.. check that intonation though..
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
09-30-2007, 05:37 PM
hollow125
Re: I need help ?
I use 9-42 EXL120 D'addario and I'm checking this stuff on IbanezRules... seems like when the open G is in perfect tune at the 24th fret its like 20 cents sharp... so I should move it back a bit I think ..
hollow125
09-30-2007, 06:12 PM
reguv760
Reviews: 12
Re: I need help ?
yep... i usually intonate from the open note and 12th fret but the concept is the same: if it's sharp, move it back... if it's flat, move it forward... don't overtighten and minor adjustment is key. Make sure you retune and double check the
bridge angle
in case it drops or raises after the string is intonated.
Reg
reguv760
allen wrench
bridge angle
locking nut
string saddle
http://www.jemsite.com/forums/f28/fs-1989-ibanez-540pii-hh-sometimes-referred-to-as-the-alex-skolnic
Alex lifeson sound neck or bridge pickup
alex skolnicks Marshall Mode Four MF350 Guitar Head?
Rush - Alex Lifeson jail release 2004 after Ritz Carlton Brawl New Years Eve 2004
08:04 PM
