Old 01-21-2002, 11:48 AM
Vai the god of Sound  is offline
Posts: 232  -  iTrader: (0)
Ibanez Edge trem - Can it be installed??
I'm thinking about chaning the floyd on my guitar and I suggested the Ibanzez Edge.
Can this be installed on any guitar (my floyd it mounted floating above the body and not within the body like the ibanez edge/lo-pro)
And plus, can I also pull up on this without my strings snapping?? Or is it just the jem that can do it?
Old 01-21-2002, 12:02 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
Ibanez Edge trem
OK, first i was going to lock this thread, because there are several topics in the ARCHIVE that address the trem swap questions, but none with non-recessed guitars, which are not popular these days.
http://jemsiteforum.com/board/forums.cgi?forum=17
First, most decent trems should allow *some* pull-up without breaking strings.
In regard to the non-recessed guitar, I'd probably swap guitars before swapping trems. The "above body" mount requires a longer tremolo block which have not been used since 1986 on ibanez guitars. See picture below. You could probably order one, but that only adds to the price. I just don't see the benefits here, given the body routing.
Old 01-21-2002, 07:47 PM
Vaibanez  is offline
Posts: 814  -  iTrader: (5)
Ibanez Edge trem
Vai the god of Sound on 10:48 am on Jan. 21, 2002
As luck would have it, I may have just the parts you're looking for. I know for fact that I have the needed studs and inserts for the Edge trem. They were tacken from an older Road Star before the resessed trems. I will have to check, but I think I even have the longer tremelo block as well.
Let me know via email if I can help.
J>:thumbsup:
Old 01-22-2002, 05:42 PM
Ibanez Edge trem
Cool Jimm, I might need the trem block because I'm buying the trem off my friend who one had it on his charvel, and it had a tremolo-routed body.
So I'll let you know if I need it
edge trem, ibanez guitars, trem block
