Tech: Setup, Repairs and Mods
Ibanez Jem 777 maple neck refinish/ question
06-01-2010, 08:19 PM
charv712
Posts: 329 - iTrader: (
Hey everybody, I recently acquired an original Jem777. The neck is super clean, It appears to have no finish on it. My questions are, am I okay to just play the guitar as is without putting a finish on the neck? I understand it will soak up dirt and grime more quickly this way, but is it going to hurt anything? If it is a huge problem, what is a simple/ yet effective way of "sealing" the fretboard....what sort of product do I need to use? Suggestions and information is appreciated. Thank you
Cale
charv712
Find all posts by charv712
06-02-2010, 06:41 AM
nsabino
Posts: 493 - iTrader: (
Re: Ibanez Jem 777 maple neck refinish/ question
charv712
Cale
Hi, what I'd recommend to get a beautiful, easy and protective job is gun stock oil. I personally use Tru-Oil, it's very easy to aplly and just follow the instructrions if you want a shiney or matte coat.
Regards,
Nelson
nsabino
Find all posts by nsabino
06-02-2010, 08:02 AM
jemaholic
Posts: 2,841 - iTrader: (
It depends on your budget. You could have it shot with a nitro finish for big bucks, you could get a can of re-ranch clearcoat poly and spray it in your garage for less, or coat it with oil like nsabino suggested.
Do some research - the guitar is worth sinking some money into so figure out what's best for you. Good luck.
jemaholic
Find all posts by jemaholic
06-02-2010, 10:31 AM
Luthier
Posts: 111 - iTrader: (
Reviews: 6
Birchwood-Casey Tru-Oil, but any good quality gunstock oil will work. Use a small amount, leave it on for just 5 minutes, then it off with a paper towel. After that, apply Birchwood-Casey Gunstock Wax. Be sure to douse the paper towel with water before disposing of it! Read the wax and oil manufacturer's instructions regarding disposal of these used paper towels.
Birchwood-Casey products are available at most sporting goods or gun stores or directly. Their web address is
www.birchwoodcasey.com
Luthier
Find all posts by Luthier
06-02-2010, 01:52 PM
charv712
Thank you guys very much! The feedback is appreciated!
charv712
06-02-2010, 02:25 PM
charv712
About how long do I have to wait to perform the whole process? And how many coats of the tru oil do I need to do? Thanks
charv712
ibanez jem777 fretboard
ibanez wizard neck vs wizard II and GRX
Ibanez wizard neck vs wizard II
24 fret neck on 22 fret ibanez
ibanez wizard vs wizard ii neck
question on the wood grain of a maple neck
Santuzzo
Other 7-string Guitars
05:08 PM
Strat maple neck question, help!
dangomles
08:54 AM
Quick question, '99 RG 550 had maple or rosewood neck?
jpwannabe
08:42 AM
Have i made a booboo? { refinish question }
Jupiter
07:22 AM
Tung oil/Teak oil refinish question...
Jupiter
04:45 PM
02:31 PM
