Old 07-22-2007, 09:06 PM
PMSM  is offline
Posts: 12  -  iTrader: (0)
Ibanez Lo-Pro 7 Bridge Template Drawings - Click here
I am wrapping up some CAD drawings for a custom 7 string guitar I am building. I am using the Lo-Pro 7 Tremolo and figured since there's such a shortage of drawings/templates, etc... for this tremolo, I'd post my drawings publicly.
I am still finalizing my measurements and the actual pocket dimensions and will post the DXFs after I have made an actual rout and checked it thoroughly. BTW, the rout I am doing is completely from scratch and in no way a copy of an actual Ibanez rout, but will feature some improvements at the cost of a little extra work in the routing procedure. I am also contemplating selling the template sets for those without access to CNC machinery to make them.
This marker is to avoid folks from attempting the drawings themselves or paying someone $$$ to get a template made. Patience and I'll have the drawings up in under 2 weeks.
Phil
Old 07-25-2007, 12:34 PM
PMSM  is offline
Re: Ibanez Lo-Pro 7 Bridge Template Drawings - Click here
Here's the partially finished drawing (still have rear rout to finish, apply dimensioning, and do a test run on some wood!)
http://www.prazision.com/images/Iban...ncomplete1.jpg
More to come!
Old 08-22-2007, 01:23 PM
PMSM  is offline
Well, it's almost near completion... the wood for the top billet is almost finished in the dry cycle so I've made some confirmations and tested a few things. Here 's what I have sofar. I will make a final revision (if necessary) after the guitar is built if I find any tweaks that can be made.
pic of guitar layout:
pic of bridge layout:
dxf of bridge layout:
http://www.prazision.com/drawings/Ibanez_Lo_Pro_7.dxf
dft of bridge layout (use with SolidEdge 2D):
http://www.prazision.com/drawings/Ibanez_Lo_Pro_7.dft
I will post again when the guitar layout and bridge is finalized (still have to test my back pocket rout since I've retained much more wood than most trem-equipped guitars leave here. I may also be able to keep more intact.)
If you would like to make your own patterns and don't have AutoCAD, download "Solid Edge 2D." It is free and what I used for these designs. It really works great! If using SE2D, use the .dft To save the dxf/dft file, rightclick - save as. The image files are compressed jpegs (pretty much here just for quick ref) and I haven't checked scaling so don't use these as templates! And a final warning... double check everything for yourself!
Phil
Old 04-05-2009, 10:45 PM
shotgunndunn  is offline
Posts: 8  -  iTrader: (0)
Phil
These links are no longer active. Can you email me your template drawing?
Thanx,
shotgunn
equipped guitar
Ibanez Dayz 2007, 13 Summer Dates ibanezusa Local Jams & Events 2 10-04-2007 12:31 PM
WTB: Ibanez lo pro bridge IanRG7421XL Classified Ads: Guitars and Gear 5 03-31-2006 06:42 PM
Which ibanez bridge? champ222 Other Ibanez Guitars (including Premiums) 6 01-21-2006 03:21 AM
fixed bridge on a floating bridge ibanez..questions Ki swordsman Tech: Setup, Repairs and Mods 15 10-17-2005 08:43 PM
Ibanez J-Custom & Prestige Overview and F.A.Q. jemsite J-Custom, USA Custom & Prestige Ibanez Guitars 0 05-16-2002 01:48 AM
