Old 01-07-2008, 08:19 PM
seaninsjca  is offline
Posts: 272  -  iTrader: (10)
Ibanez Lo-Pro refit ? D-Tuna, Big Block
Does anyone know if an EVH D-Tuna work on an Ibanez Lo-Pro Edge Trem?
Also, will a Floyd Rose "Big Block" fit onto a Lo-Pro Edge or on a Regular Edge?
Thanks!
Old 01-07-2008, 09:55 PM
LonePhantom  is offline
Posts: 5,369  -  iTrader: (6)
Reviews: 98
Re: Ibanez Lo-Pro refit ? D-Tuna, Big Block
You will not fit an EVH D-Tuna on a Lo-Pro Edge trem. The D-Tunas only work on standard profile Floyd Rose style trems. Fits on the Edge, I have one on a guitar myself.
Not too sure about the Floyd Rose big block, I'd be guessing no. Perhaps you can try and find one of the blocks off the Older Edges which are bigger. I have one on the guitar I have my D-Tuna on.
Old 01-08-2008, 01:48 AM
Thanks for the feedback, I appreciate the experienced answer.
Old 01-08-2008, 05:45 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
also, IIRC the D-Tuna doesn't work on full floating trems. it would work on those that dive only, à la EVH. if your trem also goes upward (pull) the D-Tuna would mess the overall tuning when you switch your E string to D and viceversa.
Old 01-08-2008, 05:57 PM
Reviews: 98
That's why you pick up a Tremol-no, or a Trem-setter which I've heard from some works as well. . That way if you have a full floating trem you can lock it to dive only with the Tremol-no, or tighten a trem setter so the trem doesn't move from the change in tension on the low E string.
edge trem, floating trems, floyd rose, pro edge, pro edge trem, trem setter
Leaving Ibanez guitars - No more jems for me jem7pbk JEM and Universe Guitars 141 12-11-2010 08:16 PM
WTB: Ibanez Tremolo Unfloating Block JiMoSiTY Classified Ads: Guitars and Gear 1 08-26-2008 10:46 PM
Ibanez Dayz 2007, 13 Summer Dates ibanezusa Local Jams & Events 2 10-04-2007 12:31 PM
Ibanez catalogs - call for scans jemsite Other Ibanez Guitars (including Premiums) 82 03-27-2006 11:38 PM
Ibanez trem block - that little piece some get and some dont Allen Lee JEM and Universe Guitars 2 02-27-2001 03:00 AM
