Tech: Setup, Repairs and Mods
Ibanez neck on a Strat body
10-31-2005, 09:37 PM
slugman
Posts: 256 - iTrader: (
Anyone tried putting an Ibanez pre-AANJ neck on a Strat body? I took a look and it seems like it will work-- the screw holes might not line up and the pickguard would definitely need some cutting to accomodate 2 extra frets. The route for the
neck pickup
in my body is for a humbucker so I can shift the single coil back a little. But the real test is to actually try it.
(in regards to why--> i really like the sound of my
Alder strat
, but don't like the neck, so I don't play it much).
slugman
Visit slugman's homepage!
Find all posts by slugman
10-31-2005, 10:59 PM
gunkungfu
Posts: 405 - iTrader: (
Re: Ibanez neck on a Strat body
it will work if it's a 22
fret neck
gunkungfu
Find all posts by gunkungfu
11-01-2005, 12:14 AM
frankfalbo
Posts: 1,875 - iTrader: (
It will work for both 22 and 24
fret necks
that aren't AANJ. But if it's the 24 fretter, then remember it doesn't just have the fretboard extending. There's also a little bit of neck under there to reinforce the board. That's why an RG body has a slight recess cut in it from the neck pocket to the
pickup cavity
. So you may find (depending on the height of the neck pocket) that the fretboard extension hits the body before the neck sits flush in the pocket. In that case, you'd also have to route the "RG" style channel. If you need more room in the neck pickup cavity, flip the pickup around so the triangular tab is facing the neck. Then you can get the pickup even farther away from the neck pocket to accomodate the fretboard extension.
frankfalbo
Find all posts by frankfalbo
11-01-2005, 12:51 AM
David McCarroll
Posts: 2,049 - iTrader: (
sort of, um, like, why would you bother?
Why not just put the
strat pickups
on a 3 SC scratchplate and put that on your JEM/RG?
David McCarroll
Find all posts by David McCarroll
11-01-2005, 12:56 AM
Cozi101
Posts: 260 - iTrader: (
Probably because there's more to the sound than the pickups.
Cozi101
Find all posts by Cozi101
11-01-2005, 01:37 AM
Flobanez
Posts: 5,513 - iTrader: (
How about an Ibanez EX 22 fret neck?
Flobanez
Visit Flobanez's homepage!
Find all posts by Flobanez
11-01-2005, 03:41 AM
slugman
I've got 24 fret necks only, so those have got to fit. Though I suppose I could sell one and get a 22 fret neck, except then they'd be the wrong profile, so I'd be back to where I started. But uh, that's too much work. Cutting a channel for the extension is not a problem. Thanks Frank!
And yes, there is more to the sound than the pickups
Also a cheap used alder Strat (whole) costs less than even the slab of wood I'd need to make a body out of alder, and you've got a handful of parts left over for another project.
slugman
11-01-2005, 11:58 AM
stratoskier
Posts: 770 - iTrader: (
If you don't care about the extra two frets, another option is to trim your 24-fret neck down to 22. I used an Ibanez RT650 neck (24-frets with the traditional
neck joint
) on a
strat body
. I simply used a coping saw to carefully cut off the extended fretboard at the 22 fret. With that easy mod, the neck fit just fine and there was no routing required.
stratoskier
Find all posts by stratoskier
01-13-2006, 01:37 AM
spacenuke
Posts: 670 - iTrader: (
stratoskier
If you don't care about the extra two frets, another option is to trim your 24-fret neck down to 22. I used an Ibanez RT650 neck (24-frets with the traditional neck joint) on a strat body. I simply used a coping saw to carefully cut off the extended fretboard at the 22 fret. With that easy mod, the neck fit just fine and there was no routing required.
Doesn't the RT650 neck have binding around it? You have a picture of the guitar?
spacenuke
Find all posts by spacenuke
01-13-2006, 11:48 AM
stratoskier
Yes, it does have binding. That's part of why I like those necks. There is an old thread about this guitar called "My JS700 with JS6 envy" that you can pull up. (Sorry, I don't know how to link directly to other threads). Or here are some links to the pics:
Overview
Front
Rear
stratoskier
aanj neck
alder strat
fret neck
fret necks
neck joint
neck pickup
pickup cavity
strat body
strat pickups
ibanez zps dont flutter?
what is the best strat copy
compare ibanez grx40 squier telecaster affinity
Which DiMarzio is bestl for basswood body
will an ibanez jem neck fit on an ibanez ex series body?
Check this out!!!!!
ELicari
73
08-28-2006
10:09 AM
fs ibanez curly maple body
gunkungfu
10:28 AM
RG450DX Complete Body and Neck Parts
TAorama
10:20 PM
Do S-series body with 24-fret AANJ neck go along?
aj_foes
08:15 PM
A/B test between Ibanez RG7421 and Schecter 007 Blackjack
Mind Riot
Other 7-string Guitars
02:12 PM
01:43 PM
