Originally Posted by GuitarBizarre
Why do you want a 2000 model edge? Unless your original is worn out in some way, the performance should be identical.
A lo Pro edge I could understand the reason for swapping. (FYI, lo pro parts aren't the same as edge parts)
I just want to thank everyone for responding so quickly. And yes, my original is damaged.
That is why I'm buying the 2000 model. I wanted to use all of the good parts from
the 1990 model.
