Tech: Setup, Repairs and Mods
Ibanez reverse headstock tuner upgrade to locking tuners question.
04-01-2008, 10:18 AM
unconventional
Posts: 18 - iTrader: (
Hello, I'm looking to put some locking tuners on my xiphos 6 and 7. However it appears that there are a few variables involved in doing so.
There are spretzel tuners and there are
schaller tuners
Take a look here
http://www.warmoth.com/hardware/tune...=guitar_tuners
Since my guitars have a
reverse headstock
, I'm assuming I need the "right" ones?
Now there's no real issue with me drilling a few holes, but I'm wondering also about the spretzel tuners. It appears that the base of the tuner is a different diameter than the threaded portion near the post. This seems to require some drilling out of the headstock, 1/2 way through.
What do people tend to do here? Use the Schaller ones and drill a hole for screws as these use a bracket to hold them in place, or the spretzel ones and make the peghead hole wider? I'm also concerned because my stock Ibanez tuners have 2 nubs that fit in a hole. The spretzel ones also have this, but 1 nub. I'm wondering and concerned about having to crank down the post nut hard and damaging the finish on the headstock to create enough presure for the spretzel tuner to create a new hole with it's nub.
What is the best option here?
Thanks, Kevin
unconventional
Find all posts by unconventional
04-01-2008, 10:52 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: Ibanez reverse headstock tuner upgrade to locking tuners question.
Gotoh tuners will fit better and they also come in cosmo finish. You can also try those
planet waves locking tuners
, since it seems that Ibanez has sub'd them (based on looks, IMO) to manufacture the
locking tuners
on some of the '08 models.
Jimmy
10:58 AM
jb4674
Find all posts by jb4674
04-01-2008, 11:52 AM
toneboy
Posts: 1,665 - iTrader: (
Agreed. Gotoh Magnum Lock tuners will drop right in.
BTW, I'm just curious why you're looking to get locking tuners? I've got 2 PGM301s w/reverse headstocks and they stay in tune fine. Please understand that I know everyone's tuning needs are different but I'm still curious.
toneboy
Find all posts by toneboy
04-01-2008, 12:21 PM
unconventional
Not really sure if I need locking tuners on the xiphos 6, but the 7
string xiphos
does not have a locking nut and doesn't seem to stay in tune that well. Mostly looking to pimp these thing out a bit. I don't much like the
chrome hardware
so I'm looking to blacken things up a bit.
I'm having a hard time finding those magnums in a right config for a reverse headstock.
unconventional
04-01-2008, 02:47 PM
unconventional
Anybody?
unconventional
04-01-2008, 05:49 PM
jb4674
Reviews: 6
This should retrofit the tuners
http://www.guitarcenter.com/Gotoh-Lo...72-i1129920.gc
Jimmy
jb4674
04-01-2008, 11:09 PM
losgatosrg350dx
Posts: 848 - iTrader: (
schaller locking tuners
requre no extra drilling it just looks that way, no step drilling, just put the sleeve in and then insert the tuner and tighten it, it might be a larger opening than what is on your guitar
the
schaller locking
tuners are made of some of the hardest materials any of the tuners are made of, and they are more solid with better gearing. if you want tone its schaller locking tuners you can hear the difference!!
i had a couple differnt kinds over the years and the schallers really made a difference in tone...it goes from the string to the post into a solid bushing that meets with a compressed flat metal bearing type of thing and then to the tuner body..much much more solid built then most
losgatosrg350dx
Find all posts by losgatosrg350dx
04-01-2008, 11:24 PM
unconventional
So these should work?
http://www.warmoth.com/hardware/tune...shaller_m6.pdf
unconventional
04-04-2008, 12:56 PM
Malachi
Posts: 33 - iTrader: (
you could also try
http://store.guitarfetish.com/tuners.html
specifically
http://store.guitarfetish.com/gostchlotusi.html
Malachi
Find all posts by Malachi
04-04-2008, 01:20 PM
losgatosrg350dx
hells yes the schaller will work the best i think
i use them the most, and screw the auto trim plannet waves....soo much mechanism...way less solid material to transfer tone
and the gotoh, are nearly hollow on the inside compared to the solid schaller model
losgatosrg350dx
chrome hardware
gotoh tuners
locking nut
locking tuners
planet waves
reverse headstock
reverse headstocks
schaller locking
schaller tuners
string xiphos
why doesn't dave weiner use a locking nut?
can a bottom mount R2 locking nut be used as a top mount?
jem7dbk locking stud?
what locking tuners fit agile 2000
compare ibanez grx40 squier telecaster affinity
Locking Tuners for an SZ320MH?
wizard333
01:06 PM
Locking tuners
AARRGGHHH
07:05 PM
Neck specs for ordering new Locking tuners on RG headstock?
gemini8026
01:22 AM
Schaller tuners for Ibanez rg guitars
dreammatt304
01:33 AM
Locking Tuners - to replace my gotoh tuners
cowcowcow
09:17 AM
06:16 PM
