Old 04-28-2008, 02:42 PM
Technetium  is offline
Posts: 22  -  iTrader: (0)
Ibanez, RG350DX, Edge III Bridge Angle
I own an Ibanez, RG350DX. It has an Edge III bridge, and I don't know what is the correct angle for this bridge. This is how it looks now:
I don't know whether it's right or wrong.
My mother tongue is Hebrew, and the combination of English and guitars just doesn't work for me. No one has ever taught me the names of the parts in English, so I know nothing. Some guy told me that the knife edge should be perpendicular to the stud, but I have no idea what are the knife edge and the stud. That guy also said once that Edge III bridges has a lack exposed knife edge, so that probably makes it harder for me to understand what exactly are those parts. If you guys can please try to explain it for me with pictures, then I'll be thankful. No one has ever taught me the names of the parts in English, but I really need the help.
Old 04-28-2008, 03:58 PM
mike570  is offline
Posts: 2,222  -  iTrader: (0)
Reviews: 18
Re: Ibanez, RG350DX, Edge III Bridge Angle
Technetium,
The easiest way to think of this is that the spring tension = string tension. The best way to center your trem at the right angle IMO is to use a good tuner.
Leave the back plate off and tune your strings top to bottom. If you notice your strings continue to go flat regardless of your tuning efforts, tighten the springs slightly. If they're sharp, looseten the springs a bit. Retune and keep doing the steps above until your strings stay in tune- then you will have the right angle.
Even the much maligned Edge 3 will stay in tune CONSISTENTLY with this method.
Good luck!
Old 04-28-2008, 04:08 PM
What do you mean, "tune your strings top to bottom"?
Old 04-28-2008, 04:23 PM
mike570  is offline
Reviews: 18
Sorry, low E to high E; the top of the neck to the bottom.
Old 04-28-2008, 05:22 PM
Are you sure that this is the right way to get the correct angle? I'm pretty sure that the angle is supposed to be "dictated", like, there is one angle which is right, and which is the most healthy for the guitar and the bridge. No?
Old 04-28-2008, 05:50 PM
Wild_Child  is offline
Posts: 681  -  iTrader: (1)
Reviews: 3
The knife edge needs to be parallel with the body.
http://www.ibanezrules.com/tech/setup/angle.htm
Old 04-28-2008, 06:21 PM
I have already read that page. Did you not read my messeage, like, at all? lol. I have no idea what is the knife edge, and from what I understood it's even harder to see it on the Edge III bridge.
Old 04-28-2008, 06:32 PM
mike570  is offline
Reviews: 18
True, but IMO "eyeballing" it only gets you close. You need a more precise instrument to get you closer, like a fairly good tuner. It's much more accurate than your eyes.
Old 04-28-2008, 06:38 PM
Can anyone please tell me what is the "knife edge"?
Old 04-28-2008, 06:40 PM
CosmicDebris  is online
Posts: 3,216  -  iTrader: (4)
it is what touches the anchor studs for your bridge.
Old 04-28-2008, 07:03 PM
Is this the "knife edge"?
Old 04-28-2008, 07:05 PM
Reviews: 3
A guitar being in tune doesn't mean the bridge is level. It can be in tune with the bridge sticking a mile up in the air. You tune first, then check the knife edge, compensate with the springs and tune again until it is dead level.
And yes, the knife edge is the little square block that is visible from the side of the baseplate. Rich's guide explains that.
Old 04-28-2008, 07:08 PM
What I colored in red?
Old 04-28-2008, 07:10 PM
2nd photo down in red yes that is the knife edge.
Old 04-28-2008, 07:12 PM
Why only second photo? I colored the same thing in every photo.
base plate, edge iii bridge, edge iii bridges, floating trems, pro edge, string tension
Enquiring about 2nd guitars GuitAust Vendors, Auction & Reseller Talk 27 09-24-2006 10:40 AM
Question about the edge pro bridge on higher end Ibanez elpingua J-Custom, USA Custom & Prestige Ibanez Guitars 3 11-19-2005 10:20 AM
JS edge bridge setup chemicalmagical JS (Satriani Model) Ibanez Guitars 7 04-03-2004 04:16 PM
Putting the new Ibanez ZR Bridge into a 2002 Ibanez rgt42??? ShredBird Other Ibanez Guitars (including Premiums) 6 06-16-2003 04:09 AM
JS2000CG FX Edge bridge? NOTP JS (Satriani Model) Ibanez Guitars 1 03-31-2003 01:07 AM
