Ibanez ZR trem problems - strings go flat.
Hi
I have an Ibanez S670FM with the ZR trem.
There seems to be a problem with the trem as I can have it perfectly in tune, play for a few minutes then it will be ever so slightly flat on all strings. But yanking up on the trem a couple of times will set all the strings perfectly back in tune again. Then the process repeats.
I think I have the spring tension set right, as the trem is flat against the body, the stop rod is as far into the nook as it will go and the trem block is touching the stop rod too.
Is there anything else I can do to sort this out?
Many thanks.
