Old 01-02-2002, 11:14 PM
Vai the god of Sound  is offline
Posts: 232  -  iTrader: (0)
Installing a coil tap - where to solder the wires
Alright, I've got a coil tap that I want to install in my Washburn.
It has H/H pickup configuration and it's wired to the pickup selector instead of the pots.
The Bridge pickup is washburn stock it's got one white wire and a ground wire. The Dimarzio PAF in the neck has black white and ground. The middle wire is grey which is wired to the volume pot.
The Coil Tap is typical 3 way switch with 3 connectors 4 wired as a pair, and 2 left vacant.
It looks a bit like this:
1)º *6)º
2)º *5)º
3)º *4)º
1 and 4 connected by a wire, 6 and 3 connected by a wire, 5 has a single wire soldered to it and 2 has nothing connected to it.
How would I connect it?
Old 01-03-2002, 09:06 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
I think you're out of luck with the Washburn pickup. Without a 4-conductor wire coming off the pickup, you don't have the ability to split or tap the coils.
Wiring diagrams for a DiMarzio humbucker can be found here.
bridge pickup, coil tap, dimarzio paf, wiring diagram
