Tech: Setup, Repairs and Mods
Installing peizos into an edge pro bridge.
05-23-2005, 06:41 PM
merman_93
Posts: 43 - iTrader: (
I already own an Ibanez RG 1520 with the peizo's and Roland GK 13 pin out. Unfortunately Ibanez does not offer GK electronics in any other guitar, and I need at least one good back up guitar with 13 pin out. Ibanez also does not sell the Edge Pro with GK to customers or dealers, and we all know that unless you are an endorsee, you aren't getting any custom work.
I've located a used
Double edge pro
bridge, which has the "steel inserts" where the peizo's are on my bridge, and am considering purchasing it and replacing the inserts with LR baggs peizos,(the same peizo's that are installed in the RG 1520 bridge), and adding a Ghost Hexpander to a new RG model.
Does any one have any experience with this type of work? Or good experience with the Steel inserts on the Edge Pro? If I could be certain that the LR baggs peizo's would easily fit, and that the lead wires have a good exit hole on the bridge plate, I'm ready to do some experimenting! I've studied the Photos of the Edge Pro Bridge from the Ibanez Parts Page, and as best as I can tell the Steel Inserts are exactly the same size as the peizo's, (there are no detailed photos of the Edge Pro for GK as Ibanez will not sell these, or the Double Edge Pro for any reason!).
I have had many Roland Synth controllers in the past, including the Ibanez made Roland G505, and G808, and the Ibanez original IMG 2010. The RG 1520 tracks better than anything on the market! I'm also so acustomed to the Edge Pro bridge that a standard Strat style bridge doesn't work right for me. (BTW, tuning and intonation stability are also essential for proper synth tracking with any 13 pin system, and, In My Honest Opinion,the Edge Pros' stability is unsurpassed!).
The Brian Moore i series, and Godin Freeway SA guitars support 13 pin output, and track very well. But no other manufacturer offers peizo's in a Floyd style bridge. I am also very loyal to Ibanez. I would rather purchase a Japanese AR 2000/3000 at $1900, than a similarly priced US
Gibson Les Paul
. (I've been told that I'm nuts more than a few times for making that comment).
Of course I could just purchase a second RG 1520,...but,... where is the challange in that?
merman_93
Find all posts by merman_93
07-07-2005, 08:41 PM
gouge1lt
Posts: 10 - iTrader: (
Re: Installing peizos into an edge pro bridge.
Hey merman
Did you ever get anywhere on that bridge mod? I'm in the same position. I put a GK3 on my RG470. I love my 2 Ibanez JEMs and RG470 but I want a GK pickup in the saddles instead of under the strings. I wouldn't ever modify my JEMs for a GK3 but I would consider doing what you suggest if it works. Also, I can't find the RG1520s anywhere. They're still on the Ibanez website, but no one on the web has them or Guitar Center.
Lee
gouge1lt
Find all posts by gouge1lt
05-16-2006, 08:59 PM
merman_93
"Did you ever get anywhere on that bridge mod? "
I had the #1 RMC guy in the U.S. install an RMC Poly Drive I with Piezo's in an MIJ Ibanez Artist, and was ecstatic with the results! It looked totally Factory, and tracked beautifully! That only made me more upset that I was unable to order an Ibanez RG series with the Piezo/GK set up in a guitar other than Black! Then I went another route. I had received an e-mail from a friend who owned a Caparison and felt it had a lot of similarities with modern
Ibanez guitars
, and they were in the business of making customs. I few e-mails, phone calls, and a Cashiers check later, and I had an order. I found an Ibanez Trem with Piezo's on-line for $130, and a Roland GK-Kit for Internal installation for $170, and I sent them to
Caparison guitars
in Japan and had a Custom "Angelus" guitar built for about $2200. Ibanez are my absolute favorite guitar, but I was frustrated with the attitude of Ibanez to not offer any custom work unless you are an endorsee! I didn't want to go the route of just having an RG 1520 GK re-sprayed, and although it was expensive, and it's not an Ibanez, I am very happy to have an excellant Japanese Factory Custom guitar with the Piezo/GK circuit.
merman_93
05-16-2006, 09:20 PM
Awakened Sleeper
Posts: 203 - iTrader: (
Wow, sounds like one sweet guitar. Any chance of pictures?
Awakened Sleeper
Find all posts by Awakened Sleeper
05-21-2006, 01:52 AM
jlander
Posts: 77 - iTrader: (
hi, can you post a `pic on the detail of the
double edge trem
?? ill like to modify an original edge to have the piezos... not really sure how ibanez did it...
thanks
jlander
Find all posts by jlander
06-20-2006, 11:36 AM
merman_93
This is as clear as I could get it. There is a possibility that the "steel chips"
in the
Edge Pro Trems
could be replaced with L'R' Baggs piezo's as it appears the chip and Piezo are the same size/shape.
merman_93
09-19-2007, 04:09 AM
13 pin out
Posts: 11 - iTrader: (
merman_93
I found an
Ibanez Trem
are you talking about the GK-Kit-GK3?
http://www.rolandus.com/PRODUCTS/pro...35&ParentId=55
because it looks like that includes a pickup. can you be a little more specific?
right now on **** there is a double
edge pro bridge
, but it costs over $400!
13 pin out
Find all posts by 13 pin out
11-05-2007, 01:16 AM
RexGtr
Posts: 20 - iTrader: (
My RG1520g-Bk should arrive by tomorrow.
I've wanted an Ibanez midi guitar with FR since they started producing them but can not understand why they are only produced with one paint job. Black.
I Hate black guitars (unless its a
Les Paul Custom
.) Not really a fan of yet another dot neck, I would've loved any options such as
shark tooth inlays
I curious what Merman's custom made midi guitar looks like.
RexGtr
Find all posts by RexGtr
11-09-2007, 02:51 PM
Awakened Sleeper
13 pin out
I daresay that's exactly what he was referring to, the Double Edge on it's own won't give a synth-compatible output which is why the kit would be required. The pickup supplied with the kit probably wasn't used.
Bear in mind this thread is a year and a half old!
Awakened Sleeper
03-27-2008, 05:41 AM
guitarmandp
Posts: 49 - iTrader: (
Is there an Ibanez guitar that allows you to have 3 sounds; Synth, Piezo, and
Magnetic Pickups
guitarmandp
Find all posts by guitarmandp
03-28-2008, 08:00 PM
Marco de Neijs
Posts: 4 - iTrader: (
Anyone who can help me with a good quality photo of the electronics-board inside the RG1520G? I want to compare that to the normal GK-board and try to figure out if I can directly connect the piezo's from my S2020XAV to a GK-2a board.
Thanks
Marco
Marco de Neijs
Visit Marco de Neijs's homepage!
Find all posts by Marco de Neijs
03-28-2008, 10:51 PM
Lefty Robb
Posts: 4,930 - iTrader: (
guitarmandp
Is there an Ibanez guitar that allows you to have 3 sounds; Synth, Piezo, and Magnetic Pickups?
If you got a RG21a/b and put a double edge on it..
Lefty Robb
Find all posts by Lefty Robb
01-01-2009, 12:15 PM
guitarplayerone
Posts: 37 - iTrader: (
SOMEONE HAS FOUND THE SOLUTION!!!!!!!!:
link to stickied thread on sevenstring.org
http://www.sevenstring.org/forum/pic...-possible.html
guitarplayerone
Find all posts by guitarplayerone
brian moore
caparison guitars
custom guitar
double edge pro
double edge trem
edge pro bridge
edge pro trem
edge pro trems
edge pros
edge trem
gibson les paul
ibanez guitars
ibanez jem
ibanez trem
les paul
les paul custom
magnetic pickups
shark tooth inlays
strat style
how do u measure a bridge
best humbucker bridge for strat?
how to set up edge zero bridge
I just put an Edge in my RG470!
DirtyBird31
12:22 AM
lo pro edge vs edge pro 7
cakewalkr7
12:23 AM
Edge FX bridge
Jeff
01:32 AM
06:01 AM
