Tech: Setup, Repairs and Mods
Intonation block
02-12-2006, 03:35 AM
klp2332
Posts: 280 - iTrader: (
Intonation block
I have a tremolo problem. While i was playing my D string suddenly dropped low and then i checked the trmolo. The inotation block just popped up and making the string less tight. And the fine tuner on the D string is supposed to push a bar down which i think holds the intonation block down. Now the bar has popped up, and i cant push it back down for the screw to hold it down
Any Ideas?
klp2332
Visit klp2332's homepage!
Find all posts by klp2332
02-12-2006, 07:24 AM
EL-CeeDee
Posts: 484 - iTrader: (
Re: Intonation block
Loosen string. Replace intonation block. Retighten intonation screw. Tune. Play. Be happy.
EL-CeeDee
Find all posts by EL-CeeDee
02-12-2006, 07:41 AM
klp2332
Buy a new block?
klp2332
02-12-2006, 07:46 AM
klp2332
Ok this time i used a little bit more force and got the fine tuner screw unstuck without damaging it. Now the bar is a little too short for the screw to push down.
klp2332
02-12-2006, 08:00 AM
EL-CeeDee
ah, by replacing I meant, slide it back towards the rear of the guitar,. it has slipped forward,.. thereby taking the rod out of reach of the fine tuner. Not all the way offcourse, be sure to check intonation.
Let's fix this baby
EL-CeeDee
02-13-2006, 07:49 AM
klp2332
thanks ive got it all fixed. Ive changed the intonation on all strings as close as i can. I dont bother besides i dont even have a
intonation tool
. No big performances soon so i should be fine.
Thanks Again
klp2332
intonation tool
how far off intonation in cents
Ibanez RG trem how to block
what sustain block fits trs lo pro
How to block ibanez trem
intonation makes strings tighter?
Question about setting up intonation with Edge tool...
mityjoeyoungxnj
10:04 AM
Anyone tried this? Trem block idea...
Jupiter
01:36 PM
JS (Edge Bridge) Intonation
saTa
09:21 AM
edge spring block lock, does it affect tuning stability
satchman
10:21 PM
trem block material?? brass??experts please help
schmintan
03:00 AM
12:10 AM
