Old 08-08-2006, 10:37 PM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Is there a way to "thicken" a neck?
Suppose you have a neck, and for some reason it feels too thin... other than building a new one, would it be possible to add thickness by changing the board to a thicker piece?
For example, if you wanted to go from maple to rosewood (or ebony) and picked a slab thats bigger than the previous maple board, would the whole feel of the neck be affected?
Old 08-08-2006, 10:46 PM
ibanezcollector  is offline
Posts: 3,207  -  iTrader: (29)
Images: 24
Re: Is there a way to "thicken" a neck?
no but your action and playability would..
Its not possible there is only one way, trade it for something your like, or buy a new neck.
Old 08-09-2006, 12:03 AM
jkahrs  is offline
Posts: 477  -  iTrader: (6)
How much thicker are you talking? If it's a small amount, you could have new layers of clear added to the back of the neck to thicken it up. But really, you'd probably be better off just trading your existing neck, or getting a custom made. --Jason.
Old 08-09-2006, 12:31 AM
Flobanez  is offline
Posts: 5,513  -  iTrader: (1)
I'd buy a new neck.
Old 08-09-2006, 12:46 AM
frankfalbo  is offline
It depends on the thickness of the board. I have a Wizard neck here without the board, and when I re-board it, it'll have a much thicker board. So it will then convert to something of a Wizard II. Also .058 tall jumbo frets will make it feel thicker front to back, but affect the way it feels to fret as well, giving off a more scalloped feel than say, a typical .046-.050 jumbo. But re-boarding is a huge operation, and the only reason I'm doing this Wizard is because it was water damaged and the board was 2/3rds removed already (and the scarf joint was opened up, too!) I wouldn't do it to a perfectly good neck. It's easier to get another neck, or even get a cheaper neck that's in very poor condition with worn out frets.
You could also tape a 1/16" piece of wood to your thumb! Think about that one for a minute! LOL
Old 08-09-2006, 01:15 AM
David McCarroll  is offline
Posts: 2,049  -  iTrader: (5)
Or put your fingers on a high carb diet.......
Old 08-09-2006, 05:56 AM
pawel  is offline
Posts: 2,656  -  iTrader: (3)
Never ever clean it
Old 08-09-2006, 07:47 AM
martyfriedman86  is offline
Posts: 155  -  iTrader: (0)
leave it in a swimming pool or something full of water for some time.
it will become thicker... and as useful as a cardboard-made neck
Old 08-09-2006, 11:53 AM
Thanx guys...
Old 08-09-2006, 07:56 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
i'm sure you could use some sort of epoxy mixture and brush it on.
Old 08-10-2006, 12:46 AM
chilln2music  is offline
Posts: 264  -  iTrader: (1)
I'd be interested in this as well...
Are there any companies out there that can build a neck VERY similar in feel to the old JPM neck profile?
Old 08-14-2006, 10:40 AM
timi_h  is offline
Posts: 1,104  -  iTrader: (0)
yes, ANY custom guitar builder that isnt cr*p!!
Old 08-14-2006, 03:53 PM
timi_h: Any suggestions? I'm all ears.
Old 08-14-2006, 06:26 PM
GilkyBear  is offline
Posts: 4,110  -  iTrader: (16)
Try doing shrugs, heavy weight, low reps. Should do the trick.
Old 08-15-2006, 03:21 PM
custom guitar, jpm neck, jumbo frets, scarf joint
The Super Wizard Neck ??? - is this the neck on my USA Custo Jimi D J-Custom, USA Custom & Prestige Ibanez Guitars 22 12-31-2005 12:02 AM
Jap Wizard neck on a Korean RG?? LonePhantom Other Ibanez Guitars (including Premiums) 5 11-20-2005 01:01 AM
Hands of ACID on a jem7vwh neck ZaPeRoN JEM and Universe Guitars 8 11-06-2005 08:16 AM
What is the best way to drill neck holes in new body..... SilverSurfer2 Tech: Setup, Repairs and Mods 10 04-14-2003 06:41 PM
Changing Vine inlay colors - things that make you go hmmmmmm tomizm Tech: Setup, Repairs and Mods 34 04-13-2001 03:14 PM
