Tech: Setup, Repairs and Mods
Jackson Tuner- Nut Won't Tighten
02-24-2007, 07:11 PM
guitarman13
Posts: 388 - iTrader: (
I was setting up my friends new
Jackson Soloist
today and all of the tuners were loose, so I tightened them. When I was tightening the tuner for the high E string it was starting to get tight and then all of a sudden it came loose. Now it won't tighten; I think it is stripped. I've tighten the tuners on my guitars all of the time and this has never happened to me; I'm always careful not to over tighten them. But, I guess this one might have been really sensitive. So, my question is, what needs to be replaces, the whole tuner or just the nut that I tightened??
guitarman13
Find all posts by guitarman13
02-24-2007, 07:24 PM
Dee
Posts: 8,514 - iTrader: (
Re: Jackson Tuner- Nut Won't Tighten
Try one of the nuts from the other tuners. If it doesn't work, replace the whole tuner.
Dee
Find all posts by Dee
02-24-2007, 07:33 PM
guitarman13
Do you mean switch the nut with nut from another tuner? Is it bad to have a loose tuner when the string is on the guitar? Does anyone else have any input? Because I need help ASAP.
guitarman13
02-24-2007, 09:25 PM
Dee
Loosen the string!
Dee
02-24-2007, 09:48 PM
jim777
Posts: 8,943 - iTrader: (
Are you talking about the screw that holds the tuner to the headstock? You shouldn't need it, to be honest; the tension of the string should hold it in place and it should be snug to begin with. If tyhis is really a new guitar you could always just bring it back, or else put a drop of wood glue on the screw and screw it back in again.
jim777
Find all posts by jim777
02-25-2007, 12:02 AM
guitarman13
Just to make it clear, this nut is the one that won't tighten. It just keeps turning loosely. What needs to be done to fix it?
guitarman13
02-25-2007, 12:21 AM
surfdog777
Posts: 573 - iTrader: (
Like mentioned above...loosen the string, check another nut on the tuner to determine WHICH piece is stripped, either the tuner or the nut. If it's the nut...those you can get at any guitar repair shop or Radio Shack. If it's the tuner, all you can do is replace it.
surfdog777
Find all posts by surfdog777
02-25-2007, 12:39 AM
Dee
Maybe those nuts are kinda like a nut on the end of a barrell (Ibanez style) if so, there might be a problem getting one from a place like Radio Shack.
Dee
02-25-2007, 01:15 AM
guitarman13
Yeah, they are a nut on the end of a barrel; I don't think that Radio Shack sells those. So do you guys think it is the nut or the threads on the tuner that are stripped?
guitarman13
02-25-2007, 01:58 AM
Dee
Once again, why don't you slacken the strings, take a nut off one tuner, then try it on the stripped one? We have no clue, I'm sorry. If the other nut doesn't screw up tight, the tuner threads are stripped and you'll need to buy a new tuner. If it is only the nut that stripped, try to buy a new nut at your Jackson dealer. Good luck.
Dee
02-25-2007, 02:16 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
How hard is it to buy a new set of tuners and be done with it? The tuners on that Jackson are nothing special (meaning they're not sperzels or gotohs). A whole new set of tuners will cost you about 45 bucks. If you want sperzels, it'll run you about 60 for a new set.
Jimmy
P.S.: You said the jackson was new, did you friend just get it? If so, I'd take it back to the store and get a new guitar.
jb4674
Find all posts by jb4674
02-25-2007, 02:29 AM
guitarman13
He got the guitar a couple of weeks ago. But why would he take it back over something dumb like this? He bought that guitar center warranty thing, so a new tuner should be covered by guitar center. I wonder how long it will take them to get a new tuner though.
guitarman13
02-25-2007, 06:03 AM
nightfiend14
Posts: 1,005 - iTrader: (
guitarman13
knowing guitar center they will just steal it off another jackson they have and worry about it later.
nightfiend14
Find all posts by nightfiend14
jackson soloist
guitare jackson jsx
what is a drop D tuner?
how to tighten zr trem
what kind of jackson randy rhoads
how much does custom jackson cost
FT/FS: 2 Jems (VWh & BRMR), Suhr, Jackson PC1, DigiTech GNX3 in Aussie, USA and UK
IbanezNorthwest
Classified Ads: Ibanez JEM/UV Guitars
10:35 PM
Best way to send a clean signal to tuner??
ChrisReedSmith
Gear and Equipment
12:26 PM
Rack tuner - can I put a tuner in the effects loop? - I coul
djrjems
Gear and Equipment
10:55 PM
Did Jackson Make a Jem ? - Jackson Jem 7?
zove
11:52 AM
Jackson Jem? - Did Jackson make a Jem,what was the Green Mea
zove
12:05 PM
12:37 AM
