Tech: Setup, Repairs and Mods
JEMV tremelo spring problem
09-27-2003, 11:35 PM
JS Vai
Posts: 38 - iTrader: (
Hey guys I really need help on this one.I have a 03 VSBL and is a couple months old and I recently restrung it and when I hit the whammy bar I hear the sound of springs hitting the back of the guitar either way up or down.It doesnt work if I move the springs back because then the bridge will be not paralel. So I was thinking of taking a spring of one at a time and drimiling a little line across each spring. Thanks guys for your help.
JS Vai
Find all posts by JS Vai
09-28-2003, 11:25 AM
nuno
Posts: 4,725 - iTrader: (
be careful!
and let us know how it comes out!
nuno
Visit nuno's homepage!
Find all posts by nuno
09-28-2003, 02:53 PM
Posts: 19,350 - iTrader: (
Your springs are hitting what? And you're going to try and fix it HOW?!
09-28-2003, 04:17 PM
Jammy
Posts: 868 - iTrader: (
Yeah I could do with bit of clarification on this one aswell Rich!
For example how does one "drimil" something?
-better shred than dead-ANDY
Jammy
Visit Jammy's homepage!
Find all posts by Jammy
09-28-2003, 11:39 PM
JS Vai
The springs are hitting the body,What I was planning to do was take one out and just shave off a little of the body
JS Vai
09-28-2003, 11:42 PM
I seriously doubt the springs are touching the body at all, unless you have the trem sitting 1/4" out of the guitar.
09-29-2003, 12:03 AM
ScottB
Posts: 2,208 - iTrader: (
You're probably hearing the springs resonating with the strings through the pickups.
If I were you, I'd try stuffing the inside of each spring with a couple cotton balls to dampen the resonance. It's the first thing I do when setting up a new guitar with a trem.
ScottB
Visit ScottB's homepage!
Find all posts by ScottB
09-29-2003, 11:30 AM
frankfalbo
Posts: 1,875 - iTrader: (
Sometimes if there's "router rash" that they don't clean up, then after the finish is applied it gets worse. It is usually the texture of sanpaper in there anyway but sometimes a big tentacle can touch the springs. Maybe that's it. If you could describe exactly where you see it touch we could help better.
frankfalbo
Find all posts by frankfalbo
09-29-2003, 12:36 PM
Ibateur
Posts: 2,947 - iTrader: (
He meant DREMEL, a little tool used for different kinds of work. Much like a power hand tool.
I do doubt that that's the problem, unless his springs are replacements from a camaro.
Ibateur
Find all posts by Ibateur
09-29-2003, 02:34 PM
Jem7RB MK
Posts: 2,341 - iTrader: (
Mmmmmm,Camaro .... *drools*
Rob
Jem7RB MK
Find all posts by Jem7RB MK
09-30-2003, 02:10 PM
jemke
Posts: 318 - iTrader: (
please do not rub the shielding paint off the wood in the back cavity.
jemke
Find all posts by jemke
09-30-2003, 10:05 PM
ScottB
Jemke said "rub off the wood in the back cavity".
heh heh heh.....
ScottB
09-30-2003, 10:28 PM
MicJustMic
Posts: 930 - iTrader: (
ScreamJem7
heh heh heh.....
UGH! ;-)
Mic
MicJustMic
Visit MicJustMic's homepage!
Find all posts by MicJustMic
10-01-2003, 12:13 AM
JS Vai
never mind guys I fixed it. Rich was right it was out of the body to much Thanks
JS Vai
10-01-2003, 06:12 AM
nuno
so
you
were right: your springs were scratching against the trem cavity.
did you 'dremel' it out?
nuno
how to setup ibanez zr tremelo
how to fix a tremelo bar
guitar solo problem when recording
how to unfloat tremelo
is it ok to use only one spring with a trem claw
11:12 AM
