Tech: Setup, Repairs and Mods
JPM neck question
11-11-2006, 10:16 AM
sers
Posts: 252 - iTrader: (
JPM neck question
is it possible to sand down a
JPM neck
to make it like a Wizard?
Or maybe i`ll find some troubles with the trus rod.
Sorry my awfull english, thanks in advance!!!
sers
Find all posts by sers
11-11-2006, 02:26 PM
john1880
Posts: 468 - iTrader: (
Re: JPM neck question
Hi. Your English is fine.
I have sanded down a few necks with no problems. You will only be sanding a little anyway, right?
You could also just replace it with a Wizard as thh JPM could sell for a lot of $$$$.
john1880
Find all posts by john1880
11-11-2006, 02:49 PM
eviltwin
Posts: 1,629 - iTrader: (
it will never become a wizard...btw I don't think you can go too far with the sanding. The Wizard is so thin, that it needs a special reinforcing beam next to the trussrod.
eviltwin
Find all posts by eviltwin
11-11-2006, 05:41 PM
john1880
i've looked on the internet and can't find a cross-cut view of the JPM(viper) neck, so i'm not sure how much room for sanding you have. I would imagine that it uses the same
truss rod
system as the wizard though, but i am only guessing. anybody know?
I would guess that you only need to remove a little bit of material. The nut width is different on the PGM than a wizard too. i still say to replace it with a Wizard if you are not happy with it and save the original incase you ever sell the guitar.
john1880
11-11-2006, 06:20 PM
marianozz
Posts: 2,221 - iTrader: (
sers
is it possible to sand down a JPM neck to make it like a Wizard?
errr... please, don't... come on man...
marianozz
Find all posts by marianozz
11-12-2006, 07:45 AM
eviltwin
john1880
i've looked on the internet and can't find a cross-cut view of the JPM(viper) neck, so i'm not sure how much room for sanding you have. I would imagine that it uses the same truss rod system as the wizard though, but i am only guessing. anybody know?
The wizard doesn't use the same construction, it has a circular trussrod in the bottom of the shaft and a rectangular beam on top.
The '97 JPM is derived from the relatively thick Ultra neck:
http://www.ibanezrules.com/catalogs/us/1997/index.htm
For '98 it's the Viper neck:
http://www.ibanezrules.com/catalogs/us/1998/index.htm
eviltwin
11-12-2006, 11:33 AM
sers
thanks for all the replys, i think i`m going to keep it original. it only takes me a while to be confortable with this neck after play a wizard.
sers
11-12-2006, 01:38 PM
john1880
I had JPM P4 and it had the
viper neck
so I thought all the JPMs had the viper. I didn't realize that some had the Ultra. I had the Ultra on my RG2020 and got rid of it because it was NOTHING like a wizard. HUGE! the Viper was pretty nice though. Thanks for the info EVILTWIN.
Sers. Which neck do you have? What year and model is your JPM?
john1880
11-12-2006, 07:22 PM
sers
hello john, i have a P3 `97 so i guess it`s an ultra. I never have used a viper, but after playing my jpm for a while i "forget" my lovely wizard!!
hehehe.
regards
sers
11-12-2006, 08:07 PM
john1880
You would probably be happier with the Viper. It is not as thin as the wizard, but not as fat as the Ultra. Really quite comfortable. I sold my P4 because it was just too light, but I loved how it played! I like my guitars to be on the heavier side. Not
Les Paul
heavy but on the heavy side of the basswood scale.
Sounds like you're liking the Ultra anyway...I played on my ultra for a little while and I did like it, but as soon as I went back to the Wizard, I didn't want to go back to the Ultra.
john1880
11-14-2006, 12:24 AM
OLIE_ROCKS_THE_80'S
Posts: 2,770 - iTrader: (
Reviews: 10
sers
hehehe.
regards
Good you reconsidered because you had a pretty bad idea!!!
OLIE_ROCKS_THE_80'S
Find all posts by OLIE_ROCKS_THE_80'S
01-20-2007, 07:54 PM
tony777
Posts: 296 - iTrader: (
I will buy you a wizard neck anytime to swap for your JPM;-) And I swapped my ultra on the 2020 for a JPM neck.
Tony
tony777
Visit tony777's homepage!
Find all posts by tony777
01-20-2007, 08:52 PM
sers
Hello Tony, well after being playing for a while, i can say i`m comfortable with both necks now. I still like the wizard better, but i think i should be able to play with any
ibanez neck
(Ultra, Viper, Wizard I & II).
What kind of guitar player only can play in One Kind of neck???!!!! I guess one very bad!!!
could you post a picture of your 2020, i would love see it.
sergio
sers
01-24-2007, 10:21 AM
tony777
This is the 2020 slighly customized with a homemade clear pickguard as well as Steve's special and
Air Norton combo
tony777
01-24-2007, 11:47 AM
Nesi
Posts: 195 - iTrader: (
I have both a UCEW with an Ultra neck and an SV470 with a Viper neck (although in the scale of 24.75" and with 22 frets) and the viper is thicker, smaller and toyish. After holding the ultra, it feels awkward to play the SV...
Nesi
Find all posts by Nesi
air norton
air norton combo
ibanez neck
jpm neck
les paul
production model
truss rod
viper neck
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
Jem7PBK - Question about the neck
Martijn
09:04 AM
XL neck question....
nosferatu123
Other 7-string Guitars
01:53 AM
Jem 7VWH neck question
blackfuneral
11:20 PM
question about neck bow, and bending strings.
davester1234
01:16 AM
Different Jem's = Different Neck profiles? - a question rega
jem7vwh
04:14 PM
09:38 PM
