Old 11-16-2007, 09:48 PM
jacoby66  is offline
Posts: 88  -  iTrader: (0)
Knifes on edge.
I have a Rg 550ltd in silver sand finish that I believe was made between 02-03.
I believe I either have bad knife edges or bad studs because if i move the bar a little it becomes noticeably flat or sharp, any help on this subject.?
Old 11-16-2007, 11:02 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
Re: Knifes on edge.
read this http://www.ibanezrules.com/tech/setu..._stability.htm
Old 11-17-2007, 12:24 AM
jacoby66  is offline
Re: Knifes on edge.
I might try the chapstick, how would i go about applying that?
Old 11-17-2007, 12:30 AM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
Re: Knifes on edge.
Pucker Up :P
I think it says somewhere on that page to turn your studs 180 degrees and apply some. I used a Q-Tip just because it is a tad more controlled but fingers or other tools should work. Richs site recs a dab.
Old 11-17-2007, 12:50 AM
jacoby66  is offline
Re: Knifes on edge.
Well the guitar was purchased used, but the trem and guitar has so little wear i doubt it is the knifes, but if i do a complete dive the 6th string goes pretty flat.
Old 11-17-2007, 03:51 AM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
Re: Knifes on edge.
the 6th string's saddle might need some intonation adjustment...
Reg
Old 11-17-2007, 02:06 PM
jacoby66  is offline
Re: Knifes on edge.
If I push the bar down a little they go flat, and if i want to make it kinda neutral again i have to pull up and vice-versa.
Old 11-19-2007, 03:32 PM
jacoby66  is offline
Re: Knifes on edge.
IS beeswax or cork wax ok? pls help.
Old 12-08-2007, 02:22 AM
jacoby66  is offline
Re: Knifes on edge.
IM still having tuning stability problems any ideas why?
Old 12-08-2007, 03:03 AM
Martyr Machine  is offline
Posts: 340  -  iTrader: (1)
Re: Knifes on edge.
Don't triple post.
Old 12-08-2007, 04:37 AM
Ki swordsman  is offline
Posts: 1,273  -  iTrader: (0)
Re: Knifes on edge.
they were on different days, chillax
edge pro to lo pro rya JEM and Universe Guitars 42 05-11-2011 03:54 AM
Edge III swap for another Edge model trem? lespaulreedsmith Other Ibanez Guitars (including Premiums) 36 03-14-2009 06:10 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
