Old 02-13-2006, 04:12 AM
MrChadley  is offline
Posts: 11  -  iTrader: (0)
Lo-Pro and Original Edge
If I buy a body that was routed for a Lo-Pro, can I put an Original Edge in it? The dimensions are basically the same, and I won't have to do any additional routing, correct?
Thanks.
Old 02-13-2006, 07:44 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: Lo-Pro and Original Edge
It should fit fine, but you may bottom out when pulling up (in which case you would need a deeper route in the back).
Old 07-11-2006, 01:52 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Original edge to lopro is a drop in replacement. lopro to original will require a little routing as the recess is slightly longer for the original edge due to the long allen screws sticking out. I have both style bodies in front of me and measure about 3/16" difference.
Old 07-11-2006, 04:31 AM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
ive never seen them require routing their location in the routes are slightly different. having done this myself it only limits full pullup range.
Old 07-11-2006, 06:54 AM
dex  is offline
Posts: 1,972  -  iTrader: (3)
Albee is correct - guitars routed for Lo-pro will not be routed enough to allow for the sticking bolts at the back.
Check the side by side photos for reference - clearly visible on the UV routed for Edge7 with a lo-pro7 in it there's a lot more room at the back.
http://www.jemsite.com/jem/trems.htm
ilia
