Old 11-07-2006, 10:28 AM
rya  is offline
Posts: 388  -  iTrader: (0)
Question
Lo Pro Angle
Just wanted to ask, why are they setup at an angle when setup properly?
Old 11-07-2006, 10:32 AM
djohns74  is offline
Posts: 580  -  iTrader: (0)
Re: Lo Pro Angle
They most certainly are not set up at an angle when they're proper. The base plate of the bridge as well as the saddles should be absolutely level with the body at the neutral position. The piece of the bridge body that's most easily visible in a direct side view is angled relative to the rest of it and I have no idea why this is the case. That's what leads to a lot of confusion over the proper set up of Edges.
S-man  is offline
Posts: 1,757  -  iTrader: (0)
Re: Lo Pro Angle
There not.
Old 11-07-2006, 10:58 AM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: Lo Pro Angle
The sides are angled upward and the saddles and the baseplate are level to the body. Triangles are strong, the edge pro has a thicker baseplate to compensate for not having the raised sides.
Old 11-07-2006, 03:55 PM
andy7jem  is offline
Posts: 6,504  -  iTrader: (0)
Re: Lo Pro Angle
The knife edges should be level
Old 11-07-2006, 04:04 PM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Re: Lo Pro Angle
This should help
http://www.jemsite.com/tech/1setup.htm#step1
Old 11-09-2006, 07:31 AM
GTR-MAN  is offline
Posts: 1,056  -  iTrader: (0)
Images: 8
Re: Lo Pro Angle
The lo-pro does look like it's at an angle when it's set up properly, but that's because you're looking at the wrong part of the trem. Because of the design of the lo-pro you have to look at the knife edges instead of the base of the trem. Also the squared off top of the saddles are aligned with the knife edges too. The Pic that's in the link that JJEMMER777 gave you doesn't show the knife edge very well, but the edge pic shows it if you look closely enough. Similar design, they both look like they're at an angle. If an Edge Pro was looking like it's at an angle then it would be because they're designed to look flat, but the lo-pro and edge trems look at an angle so you have to use the knife edges to tell if it's level with the body. I'm probably making this confusing. I have a hernia so I have to take Vicodin and I get a little loopy. Sorry. I'll stop now.
base plate, edge trem, edge trems
setting the trem angle...questions atarilovesyou Tech: Setup, Repairs and Mods 2 03-07-2006 04:39 AM
Shimming neck angle.... Rotti Tech: Setup, Repairs and Mods 6 12-28-2005 03:48 PM
Having problems with trem angle... Adagio_777 Tech: Setup, Repairs and Mods 13 09-20-2005 06:33 AM
Need help with lo-pro trem angle... ibanezlover Tech: Setup, Repairs and Mods 4 08-27-2004 11:50 PM
Correct angle for lo pro edge? big h Tech: Setup, Repairs and Mods 16 04-09-2003 01:25 PM
