Old 08-12-2008, 06:08 AM
v1ncent1993  is offline
Posts: 22  -  iTrader: (0)
Lo-Pro Edge Problem
Hi, I've got a 2000 Ibanez Floral Jem with a lo-pro edge and when i pull up the low e string goes out, but when i dive it comes back in tune. It only happens with the low e, the other strings go back perfect. Do any of you know what the problem might be and how i can fix it?
Thanks.
Vincent.
Old 08-12-2008, 06:24 AM
alecmm61  is offline
Posts: 548  -  iTrader: (0)
Images: 6
Re: Lo-Pro Edge Problem
dead low e string?
Old 08-12-2008, 02:49 PM
ScottB  is offline
Posts: 2,208  -  iTrader: (12)
Images: 8
Try turning the locking pad for the B and E strings 180 degrees. It may have become grooved and if the pad has been replaced upside down, the E could be sliding through the old B string groove.
Old 08-17-2008, 02:40 AM
I put on a new set of strings ad stretched them in and now they all go slightly sharp when i pull up. I had a look at the tech section at Ibanez Rules and it looks like i have either fat knife edges or bad posts because my guitar goes sharp when i pull up but if i push it down a bit and release it it will return to pitch. Is there a way for me to find out whether it is the knie edge or posts that are bad and how can i fix it?
Thanks.
Vincent.
Old 08-17-2008, 03:26 AM
WOW that chapstick thing ACTUALLY works!!!!!
It's all good now.
Thanks.
Old 08-23-2008, 09:53 AM
Is the chapstick thing only a temporay fix? will i have to keep applying it?
Thanks.
Vincent.
Old 08-23-2008, 10:26 AM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
If you ever notice tuning issues again just reapply.
Old 08-23-2008, 04:15 PM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
Yes, just as much as needed. Chapstick is a valuable addition to the toolbox! Also check that all parts - nut screws, locking pads, neck screws, saddle screws - are tightened nicely so that nothing slips. Don't overtighten though, obviously.
'87
Old 08-24-2008, 01:34 AM
Should I just file the knife edges to save me the trouble of reapplying it? will that stop me having to apply chapstick or will i still have to apply chapstick to get it perfect anyway. Because i am not too comfortable with taking the trem off and messing around with it but i don't want to have to keep applying chapstick too often.
Thanks.
Vincent.
Old 08-24-2008, 01:47 AM
You don't have to take the trem off to put a spat of chapstick on the studs. Turn them 180 degres, apply lube, and turn back.
Old 08-24-2008, 02:41 AM
I mean taking it off and sanding the knife edge.
Old 08-26-2008, 05:24 AM
If i sand the knife edge down, will i still have to use chapstick? because i find it abit of a hassle to have to keep putting chapstick.
Thanks.
Vincent.
edge, lo pro edge, problem, tuning
Edge Problem 560licious Other Ibanez Guitars (including Premiums) 2 03-23-2007 10:54 AM
Double edge problem! tony777 Tech: Setup, Repairs and Mods 2 05-20-2004 11:14 PM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 09:59 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 02:43 PM
edge tuning problem - edge tuning problem johank Tech: Setup, Repairs and Mods 1 10-03-2001 10:30 AM
