Old 02-09-2004, 11:10 AM
RogerDavis  is offline
Posts: 6  -  iTrader: (0)
Lo Pro Edge removing intonation screw
On my Universe I am unable to remove one of the intonation screws because the groove for the allen key is worn - I am unable to get any grip with an allen key. Can anyone advise of a way to get this screw out so I can replace it without causing damage to the bridge?
Any help much appreciated! Cheers, Roger Davis
Old 02-09-2004, 11:15 AM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
first try a new allen wrench.
next, you can use a dremel and a cutting wheel to make a slot for a screwdriver. alternately, if the saddle is close to the bolt, you use some wd40 on the area and then tap the saddle out from under the bolt with a punch, then remove the saddle nut with your fingers... glen
Old 02-09-2004, 01:13 PM
steve  is offline
Posts: 590  -  iTrader: (4)
A small screw extractor might also do the trick.
Old 02-09-2004, 02:14 PM
Rich  is offline
Or just do it the easy way
http://www.ibanezrules.com/tech/setup/rounded_head.htm
Old 02-09-2004, 02:18 PM
jemsite  is offline
Administrator
Images: 11
lol... good old powertools.
i'd highly recommend removing the bridge from the body if you're doing it with a drill. alot of room for error and slippage there. ...glen
ps - did you ever try tapping the saddle out rich?
Old 02-09-2004, 02:25 PM
Rich  is offline
If the head is rounded it's trash, why bother chancing cracking the saddle when it literally takes 20 seconds to free it?
Now don't run with scissors or chew on razor blades either!
allen wrench
