okay,
seems like an easy fix. every once in a while when i use the trem bar, it has this annoying slack to it that feels kind of like ..........um.......sort of like a joystick when it's worn out a little bit and it has that neutral slack that doesn't affect anything. when i rotate the
trem arm around clockwise, it seems to tighten that thing that it is situated in and the problem goes away, but it doesn't tighten it completely so that annoying bar slack gradually comes back the more the trem hole gets loose, so now i'm curious how i can tighten the hole up a bunch, to keep it from doing this. sorry, that probably didn't make much sense. thanks in advance!
~joel
