Tech: Setup, Repairs and Mods
LO TRS II nail polish
11-22-2003, 05:20 PM
prsdimarzio
Posts: 2 - iTrader: (
In the tech/setup section of this site, a mod suggests using nail polish
http://jemsite.com/tech/t_3other.htm#lotrsarm
to improve the performance of the trem. has anyone done that and if so how does it work out? and also how would you remove the nail polish if it makes the trem worse?
prsdimarzio
Find all posts by prsdimarzio
11-22-2003, 07:25 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
Re: LO TRS II nail polish
prsdimarzio
Nail polish remover can be used if it makes the trem worse
. Just be careful with it, and no it cant really make it worse, but I most add this is just a temporary fix, and it may be better to looke for the bar attachment from an
edge tremolo system
if you continue to use the trs
sniperfrommars1
Find all posts by sniperfrommars1
11-22-2003, 11:31 PM
prsdimarzio
i thought about nail polish remover too..but i was wondering if it would be corrisive to the metal
prsdimarzio
12-01-2003, 09:37 PM
Dr_Guitar
Posts: 52 - iTrader: (
That tip suggests putting nail polish on the end of the arm. I put the clear nail polish on the threads & tighten the collar till the arm is at the desired tension, then let it dry. This works on OFR's as well.
Dr_Guitar
Find all posts by Dr_Guitar
12-11-2003, 12:50 AM
Biff
Posts: 5 - iTrader: (
sniperfrommars1
prsdimarzio
. Just be careful with it, and no it cant really make it worse, but I most add this is just a temporary fix, and it may be better to looke for the bar attachment from an edge
tremolo system
About how much does the bar attachment from an
Edge Trem
cost? Also, can i just switch out the bars if i buy the edge one? Cause from what ive seen the edge bars dont have a screw in system.
Biff
Find all posts by Biff
12-11-2003, 06:48 AM
dex
Posts: 1,972 - iTrader: (
Forget the nail polish or the EDGE arm, just head to the kitchen and with and exacto knife cut yourself a little cube of washing up sponge (preferably unused) measuring 1/4".
Now stuff that all the way down the
arm holder
, insert the arm and screw the collar.
Flutter away.
ilia
dex
Find all posts by dex
12-11-2003, 07:26 PM
Biff
dex
Now stuff that all the way down the arm holder, insert the arm and screw the collar.
Flutter away.
ilia
Did you really do that? And did it work? And also, would it be difficult to get it out if it didnt work?
Biff
12-11-2003, 09:52 PM
dex
On more guitars than I care to remember and rigth now I have 2 Schaller FRII trems with sponge stuffed down the arm holder.
Very easy to get out with a small screwdriver but once you try that you won't ever be getting it out.
ilia
dex
12-12-2003, 01:13 AM
Biff
dex
ilia
All right ill give that a go. And just wondering, does the trem bar from Lo
Pro edge
fit the Lo TRS II?
Biff
12-12-2003, 03:52 AM
nuno
Posts: 4,725 - iTrader: (
Biff
...does the trem bar from Lo Pro edge fit the Lo TRS II?
i dont know if their diameters match, but the Edge arm is a snap-in bar, while the TRS is a screw-in bar.
nuno
Visit nuno's homepage!
Find all posts by nuno
12-12-2003, 04:10 AM
AndrewTodd
Posts: 43 - iTrader: (
This is all very interesting - I have a TRS in my '94 RG470 and it has a push in bar, exactly the same as the Edge....
The bar is plain, with just the two nylon collars on it and the
trem block
has the adjustment nut attached to it where the trem bar pushes in.
AndrewTodd
Visit AndrewTodd's homepage!
Find all posts by AndrewTodd
12-12-2003, 05:05 AM
dex
Well that's because whoever owned the guitar before you must have changed the arm holder to an EDGE arm holder.
ilia
dex
arm holder
edge trem
edge tremolo system
pro edge
trem block
tremolo system
what is nail vibrato
How to clean or polish rosewood furniture
how to polish frets
what to use to polish frets
Cosmo Black hardware polish
08:34 AM
