Tech: Setup, Repairs and Mods
Lo TRS not returning to neutral
05-14-2007, 02:24 AM
eg
Posts: 259 - iTrader: (
I have this problem with my Lo TRS. It doesn't seem to return to its neutral position.
For example, when all strings are in tune, depressing the bar will make all the strings go flat by about 5-10cents. Likewise, pulling up from neutral will cause all strings to become sharp albeit a little less, maybe around 5 cents or so. I found out that this is worst on the thicker strings esp the low E and A strings.
Once the strings are sharp or flat, slightly moving the trem in the opposite direction will then make the notes return to neutral.
Anybody can recommend me some ideas other than of course changing the trem. Thanks
eg
Find all posts by eg
05-14-2007, 02:28 AM
Posts: 19,352 - iTrader: (
Re: Lo TRS not returning to neutral
Drop the bar to the body and let it return to neutral. Unlock the nut and tune [or if it's close just use the fine tuners]. Lockdown, depress the bar, return, fine tune. Does it go out on a dive after that?
05-14-2007, 02:32 AM
eg
Rich, what do you mean by drop the bar to the body? Do you mean that when unused the bar should be hanging perpendicular to the strings rather than parallel when unused?
Also, are you implying that the weight of the bar on the trem will cause the tunings to be out a little? I usually tune with the bar unattached or with it parallel to the strings.
eg
05-14-2007, 02:46 AM
Depress the bar, let it return to neutral.
05-14-2007, 02:51 AM
eg
You mean this...
Depress
Return
Retune
Depress
Return
---> Should stay in tune after this?
eg
05-14-2007, 11:49 AM
Chakakanagen
Posts: 35 - iTrader: (
That's what he's getting at, yes. He's trying to see exactly what your problem is and he's starting with the most obvious thing first. Are those new strings?
Chakakanagen
Find all posts by Chakakanagen
05-14-2007, 09:41 PM
eg
I think I've had them on for like a month or so. Will try Rich's diagnosis suggestions first. Stay tuned
eg
05-21-2007, 12:15 AM
eg
Some updates.
I think the position of the bar somewhat affects the tuning of the strings. Leaving the bar forwards will tend to flatten the strings while leaving it backwards will the not sharpen it.
The only position to keep the trem neural is to let it dangle perpendicular to the strings when not used.
Anybody has made any similar observations?
eg
05-21-2007, 08:25 AM
neptoess
Posts: 303 - iTrader: (
it shouldn't be that drastic unless you're holding your guitar like parallel to the ground or your bar weighs 10 lbs
neptoess
Find all posts by neptoess
05-21-2007, 09:41 AM
nuno
Posts: 4,725 - iTrader: (
neptoess
or unless you mean "out of tune" something about 0.00000000000000000000000000000000000001 thousandth of a cent
nuno
Visit nuno's homepage!
Find all posts by nuno
05-21-2007, 12:11 PM
Chakakanagen
Are you sure your strings are stretched properly?
Chakakanagen
05-21-2007, 12:36 PM
eg
I think they should be stretched properly.
Back to Rich's suggestion.
I depressed the bar and retuned it to pitch and it will continue to stay in tune as long as I'm diving. Once I pull the trem up, the strings will tend to be a few cents sharp (~5%) and if I were to tune them to pitch at that moment, they would be flat by a few cents once I do a dive.
Seems that I can only tune it to pitch in favour of a certain direction of trem usage.
Any help guys?
eg
05-21-2007, 01:04 PM
Chakakanagen
From Rich's site:
http://www.ibanezrules.com/tech/setu..._stability.htm
Note - 100% trem float would mean it comes back from tune 100% of the time from whammy dives, but also 100% of the time from pull ups. Your guitar should always come back in tune 100% from dives. If it doesn't, you have a problem that can be found above. But guitar very rarely come back 100% from a pull up, in fact few will be at 98 or 99% from pull up which means neutral will have a few strings off by a very few cents, something that the tuner sees but your ears really don't hear. I consider a 95% float one where several strings come back far enough out I can hear it. All of these can be reset to perfect tune by pushing the trem down past neutral to low neutral.
Chakakanagen
05-21-2007, 10:16 PM
eg
That's good info man.
To sum up, it is a must for the strings to return 100% to pitch after a dive.
However, returning to 100% pitch after pullup is not always possible and can always be corrected by pushing the trem down again.
So, I guess I'll just have to make sure that it stays in tune after returning from a dive.
Might also try the chapstick tip to fix the pullup return a little
10:37 PM
eg
05-22-2007, 08:46 AM
neptoess
maybe it's your knife edges? I heard TRS's had real soft knives
neptoess
ADA gear returning?
Only bottom 3 strings not returning to pitch?
chilln2music
01:53 AM
Help! *New pickup sounds like doo-doo
ashlock
05:55 AM
08:30 PM
