Old 10-19-2009, 07:18 PM
loran333  is offline
Posts: 18  -  iTrader: (0)
locking nut lock bolt
hi , today I broke one of the locking nut lock bolt , the turn of the allen key is loose , so know I can't unscrew it.
I don t find anything about that here , so if somebody know a methode , I take it.
Old 10-21-2009, 03:30 AM
moonlight  is offline
Posts: 353  -  iTrader: (0)
Re: locking nut lock bolt
Take the other locks off and grab the head of the stripped bolt with a pair of pliers and unscrew it. Then buy a new bolt.
Old 10-21-2009, 07:19 PM
loran333  is offline
It 's impossible to grab the head of the screw because it 's in the hole wood in the back of the neck.
This is one of the two screw that lock the entire floyd nut on the back of the neck . It 's a rear mount nut , and I round off the Allen hole of one of these screw.
Old 10-21-2009, 09:28 PM
OK, try lightly taping a 7/64 allen wrench into the head while supporting the string side of the nut on something that wouldn't damage it, like a magazine on a table. If that doesn't work get an easy-out screw extractor that fits in the head. Be careful, it's easy to cause more harm than good. If you don't feel comfortable doing this take it to a pro.
Old 10-21-2009, 09:32 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
Drill the head off of it and replace the bolt.
Old 10-22-2009, 12:13 AM
loran333  is offline
Rich , if I understand correctly the procedure is the same as your "rounded intonation screw" in your tech section.
Moonlight , I m gonna take it to a pro (one of my friend is luthier) the question was only for my knowing. (I can't ask my friend because he is in holidays)
big thanks for your responses.
Old 10-22-2009, 12:47 AM
I've never had to drill a screw out of a guitar but have done that on a lot of other stuff. A left hand or reverse drill works good because it usually will grab on to the screw and unscrew it before the head is drilled off. Just make it a little easier sometimes.
locking nut
Locking stud lock diameter? jim777 Tech: Setup, Repairs and Mods 6 06-02-2007 03:15 PM
Notes detuning the moment i lock the locking nuts..pls help.. kelvin55 Tech: Setup, Repairs and Mods 9 12-25-2005 08:39 AM
convert lock-nut to non-lock nut stratoskier Tech: Setup, Repairs and Mods 36 11-15-2002 11:01 PM
I lost one of the locking nut lock screws from my RG HELP!!! Aussie_520QS Tech: Setup, Repairs and Mods 0 07-13-2002 04:44 AM
