Old 01-17-2008, 08:53 PM
Lunatic  is offline
Posts: 16  -  iTrader: (0)
Looking for a little setup help
Hi,
I've got a 1990 540SCT6 and it's got a fret buzz problem. I had it set up by a local shop (Steve's Music in Toronto) and I'm not really happy with the results. This guitar pretty much hung on my wall for a bunch of years that I just didn't play and I decided a few months ago to get it set up and start playing again. Since then it's had some pretty severe fret buzz, particularly on the low E and A strings. I'm starting to think the neck is warped. When they set up the guitar they cranked down the high E side of the bridge pretty far, I think trying to compensate for the neck. Here's a couple of pics of the bridge to try and show what I mean.
Hopefully some of you have some suggestions for me or maybe someone can recommend a good guitar tech in Toronto?
I seem to recall that I used to be able to see the bottom edge of the trem when the guitar was set up properly. I think they screwed the studs down quite a bit to get the action down.
You can see the gap difference between the two posts on the bridge
From the top
From the bottom
and a pic just for fun...
Old 01-19-2008, 12:59 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: Looking for a little setup help
SOme basic tips to get you started. First, sight down the edges of the neck. Are both sides straight? If not, are both sides the same(they should be because a twisted neck is about useless). If the neck is curved forward(strings get higher up the middle of the neck, truss rod needs to be tightened. If the strings are lower up the neck(I'm referring to the area between fret 4 and 12), then the truss rod is too tight. I do truss rod adjustments in eighth to quarter turns of the wrench and let it settle for a minute. Once the neck is adjusted correctly(just a slight bow, commonly called "relief", but not dead straight), then move on to the bridge. Put new strings on(no sense setting up a guitar with old ones) and set the bridge height more level before you fine tune it. Basically, you want to have the strings as low as you can get without having bad fret buzz(some folks don't want any but a little is usually okay). Don't forget to try bending the strings to see if they fret out as you bend(raise the bridge a little till the notes sustain). You may need to raise or lower the pickups(too close and the magnets can kill the string sustain). ALso check the nut height. I hold the string down between frets 2 and 3 and look at fret one. If the string is laying right on fret one, the nut is probably too low(have a pro replace it). If the string has a lot of distance above the fret, the nut could likely be cut a little deeper(a job for a pro). Once all those details are set, then intonate and go play. BTW, that's a good looking guitar.
Old 01-20-2008, 10:18 AM
Lunatic  is offline
Thanks for the suggestions, I'm going to give them a try this week and see how it goes.
fret buzz, guitar tech, nut height, rod adjustment, truss rod, truss rod adjustment, truss rod adjustments
WTT rack setup for an ENGL Powerball S420 Classified Ads: Guitars and Gear 2 02-02-2007 11:52 PM
UV7BK setup Demogorgos Tech: Setup, Repairs and Mods 1 04-26-2006 07:51 PM
eventide H3000 series setup help eaton Gear and Equipment 1 07-10-2003 11:38 PM
Setup problems with my DBK...good price for a quality setup? Guitarlos2 Tech: Setup, Repairs and Mods 7 07-10-2003 03:39 PM
Changing string gauges - What's to be setup again ? Wicked Blade Tech: Setup, Repairs and Mods 2 04-22-2001 02:21 PM
