Old 06-26-2003, 01:57 AM
genesis  is offline
Posts: 37  -  iTrader: (0)
Loose Truss Nut (REALLY need help here guys)
I am having fret buzz on frets 2-7 on the high e string, and according to the tech page, im supposed to loosen my truss rod.
thing is, i have loosened it and still it has fret buzz, and furthur attempts to loosen it is not possible because the nut is so loose, i can basically turn it with my fingernail!
wad should i do now? tighten the nut? but wun it tighten the rod too?
Old 06-26-2003, 04:10 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
fret dressing?
Old 06-26-2003, 09:52 AM
genesis  is offline
before i had this fret buzz problem, i actually had quite perfect action to me though, and there was no buzzing at all, that is until two nites earlier where i increased my lopro's height and the buzzing came back.. quite wierd dun u think?
Old 06-26-2003, 12:38 PM
nuno  is offline
yes it is,
but it happens to me sometimes too. dont know what to say, i'd just suggest you to bring it to a pro, or just keep the neck a couple nights "under-press", tightening the truss-rod every now and then.
that's what i do in these cases, and it works great.
Old 06-27-2003, 12:03 PM
genesis  is offline
so there's really no way of furthur loosening my truss rod? cause im not that big on under presses or wadsoever... Rich, any ideas? im counting on you now boss~
Old 06-27-2003, 12:13 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
what nuno said.
snugly tighten the trussrod nut so it doesn't unfasten and detach.... you are out of adjustment there.
you're probably going to have to get a competant tech to work on the neck and restore the forward bow. They can also check the neck for high frets that might need to be corrected. Assuming the frets were cut properly and bow is possible, they will clamp and heat the neck restoring the bow, allowing the trussrod to do the *minor* adjustments again... glen
Old 06-27-2003, 12:56 PM
genesis  is offline
hmm okok in that case, i will go look for a tech then hahaha.. thanx guys!
fret buzz, high frets, truss rod
