Low fret repair - Jemsite
Old 02-09-2010, 04:26 PM
skins345669  is offline
Posts: 846  -  iTrader: (0)
Low fret repair
I've found that the 1st fret on my S is a little low, and I don't want to have to raise the action. Are there any ways of solving the problem without having to pay a load for someone to fix it? The fretboard is bound, if that counts for anything.
Old 02-09-2010, 08:19 PM
littlephil  is offline
Posts: 422  -  iTrader: (0)
Re: Low fret repair
If its only the first fret you could find a luthier to replace just it, that shouldnt cost too much.
If its more than just the first fret you might need to get the nut lowered, again, that shouldnt cost too much either.
Old 02-09-2010, 10:13 PM
BJRGuitars1  is offline
Posts: 11  -  iTrader: (0)
Re: Low fret repair
If the 1st fret is low, wouldn't the string be high? If you meant 'the 1st string is low' then the nut needs to be raised. Locking nuts need a shim to raise them and a conventional nut needs to be replaced.
Old 02-09-2010, 10:50 PM
Weezel  is offline
Posts: 58  -  iTrader: (0)
Reviews: 24
Re: Low fret repair
Just take in your guitar to a luthier and have your frets leveled! Shouldnt cost that much
Old 02-10-2010, 02:01 PM
Re: Low fret repair
When I say the first fret is low, I mean the first fret is low. When I play it, the string rattles on the second fret. Nowhere else is there any buzz.
How much roughly is a total level? It might help me get a few precious micrometres out of my action
Old 02-10-2010, 04:30 PM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
Re: Low fret repair
this truthfully happened to me. I had my frets re crowned and the action adjusted and now I literally HATE playing my guitar because the frets are way too low for my taste (they had to file a lot of fret away it seems) so I payed money for the fret work when I just should've got a new fret job instead.
Old 02-10-2010, 06:31 PM
Re: Low fret repair
What didn't you like about the frets being low? Does it affect how you feel the frets as you go up and down the neck or is it a case of fingers being closer to the actual board?
Old 02-10-2010, 08:13 PM
Weezel  is offline
Reviews: 24
Re: Low fret repair
With any guitar from any brand 99% of the time the frets are never leveled. You should always take a guitar in to get a setup after purchasing. Like I said, see a luthier about it he'll most likely level the frets out and your guitar will be good to go and if thats not the case then he'll tell you what yuh need. It costs me around $20usd to have my frets leveled and polished I dont think thats expensive
Old 02-11-2010, 11:19 AM
nsabino  is offline
Posts: 493  -  iTrader: (0)
Re: Low fret repair
Hi guys, isn't crowning also very important?
Regards,
Nelson
Old 02-11-2010, 02:16 PM
Re: Low fret repair
Fret level and polish it is then!
Old 02-11-2010, 03:02 PM
Foulacy  is offline
Posts: 354  -  iTrader: (0)
Re: Low fret repair
Regards,
Nelson
crowing is mostly for feel (also intonation), not to get rid of buzz. plus, you would never crown a fret randomly, it's almost always done after a level when the top of the fret has a flat spot.
Old 02-11-2010, 03:28 PM
Re: Low fret repair
Right. The only place I can find in and around Surrey is Feline Guitars in Croydon, and they want to charge me at least 100 for it. Does anyone one else know of any places which won't cost that much?
Old 02-15-2010, 07:42 PM
Re: Low fret repair
What I do in my shop for this kind of thing is to use a fret nipper - used for pulling frets - and pull the low part of the fret up, and then use ca glue to set it in place. On the road I have used razor blades to lift frets by working them in between the fret board and bottom of the fret and then glue it as described above (i.e., if the fret was hit on a cabinet or stage, etc). If needed I will then level, crown and polish the fret. Crowning restores the fret shape as leveling widens the crown and can negatively affect intonation and playability.
Old 11-02-2010, 02:51 PM
musikron  is offline
Posts: 941  -  iTrader: (0)
Re: Low fret repair
I would not do that personally. Thats cutting your nose off to spite your face.
fix , fret , low , repair
Help, action high at 5th fret, low at 19th fret Rachmaninoff Tech: Setup, Repairs and Mods 3 06-06-2008 12:03 PM
Got a new guitar, but its got fret buzz on one string at one fret how to fix? ibanezcollector Tech: Setup, Repairs and Mods 6 11-25-2006 07:43 PM
If I'm getting fret-rattle from the 12th to the 18th fret...? Superuser Tech: Setup, Repairs and Mods 0 02-03-2006 01:11 PM
My fretboard is lifted near the 1st fret. Tips on repair? Stygian Tech: Setup, Repairs and Mods 7 01-04-2006 08:41 AM
Strange fret buzz - Only at 16th fret, G string carlos seo Tech: Setup, Repairs and Mods 3 02-07-2001 12:12 AM
Powered by
