Old 08-11-2009, 06:07 PM
nsabino  is offline
Posts: 463  -  iTrader: (0)
Re: Maple Neck Care - Satin Gun Oil Finish
Originally Posted by Ayrton View Post
Unless the original finish is gone, I would not mess with the fingerboard except to clean in. The inlays are synthetic, and you can polish them out like any other plastic.
Read the sticky about maple board cleaning, and hit me with questions.
Hi Ayrton, well it's an 18 year old axe and not all but some of the finish is gone.. what's your tips man, I've read the sticky.. what would you recommend I use for polishing the inlays?
thanks alot,
Regards,
Nelson
Old 08-11-2009, 08:00 PM
Ayrton  is offline
Here are some general tips, but each neck is going to be different.
I use a combination of steel wool, sandpaper and a razor blade to clean dirty maple. What you will need exactly, and how much really depends on the neck.
I don't know how much experience you have with something like this, but start with the steel wool. ONLY move in the direction of the grain when using sand paper or the razor.
Be careful using sandpaper with rougher grit than say 320. Also be mindful of the inlays.
You will various grits of paper (220,320,400,600,800)
Your goal is to get the neck as clean as you can, and then use finer and finer grits of paper to polish out the inlays (you can sand the surrounding wood as well).
Once you are happy with the neck, then you can apply the Tru Oil. I use a Q tip when working a maple board that has frets installed. I don't like to get the oil on the frets (only to have to scrape it off later).
Apply a coat of oil to each fret and let it dry for an hour or two. Dry enough is when it is dry to the touch. You can scuff up the previous coat with some steel wool (0000), but just knock off the shine.
Keep adding coats until you are happy. I tend to go 4-5 on the board, and 2-3 on the back of the neck.
Below is a thread where I did the back of a Washburn neck.
(I thought I had posted this thread here, but I guess not.)
http://www.seymourduncan.com/forum/s...d.php?t=157169
Old 08-11-2009, 08:19 PM
nsabino  is offline
Thanks alot buddy, I'm more or less like you, handy with tools and a reader then I become a DIY. Usually the jobs I tackle come out pretty decent but I need to know facts beforehand. Thanks for your info, now I need to wait for the oil before the string change...
regards,
Nelson
Old 08-12-2009, 02:42 AM
Ayrton  is offline
Nelson,
Feel free to hit me up if you have questions, or get in a jam.
One very nice thing about Tru Oil, is it is damn near idiot proof to apply.
Old 08-12-2009, 12:41 PM
nsabino  is offline
Nelson,
Sure thing Ayrton, thanks alot for your help.
Regards,
Nelson
Old 08-12-2009, 02:41 PM
Sickbean  is offline
Posts: 262  -  iTrader: (0)
Right I think I'll give the 0000 wire wool/ Tru Oil combo a go then.
Shame, cause I quite like the streaky look of a dirty maple board, but it's starting to gunk up and hinder playing now
Old 08-13-2009, 01:19 AM
Ayrton  is offline
Keep in mind, any dirt/stains that are there when you apply the oil, will always be there.
Make sure you are happy with how it looks before adding Tru Oil.
Old 11-08-2010, 10:53 AM
PaoloOrtega  is offline
Posts: 8  -  iTrader: (0)
hey guys i really want to try this kind of finish is it a good idea to put on my ibanez S it has a maple neck and i really want a thin coat just to give me that nice satin finish feel. thx....
Old 11-08-2010, 11:45 AM
AlaskaBat  is offline
Contributor
Posts: 6,645  -  iTrader: (17)
Images: 11
Reviews: 94
Kumosta ka, Paolo?
Yes, this will work with any neck/fretboard. As Aryton said, make sure to clean the fretboard before applying the oil. I always use an old electric toothbrush to clean mine. As for polishing the frets afterwards, I use jewelers polish applied with a Dremel and jewelers buffer bit.
Old 11-09-2010, 04:51 AM
haha its Kamusta and im okay thank you.. thank you so much for your reply i will try it as soon as i get my hands on some tru-oil i will probably go to a gunshop or sporting goods store either this week or the next ill let you know what happens again thank you.
Old 11-17-2010, 06:12 AM
how do i know that i haven't steel wooled the tru oil
Old 11-17-2010, 02:00 PM
Ayrton  is offline
Tru Oil when it dries is quite shiny, so the wool knocks off the shine to accept another coat.
Just a few light passes is all you need with the steel wool.
Old 11-24-2010, 10:15 AM
alright thanks man i put the finished it already i put 4 coats and buffed with steel wool really nice finish although when i go from a cold room to a warmer room the neck tends to get moist do you have any tips for that.
cleaning, g&l, maple neck
What to do when a neck's satin finish becomes glossy? toneboy Tech: Setup, Repairs and Mods 24 04-29-2007 09:27 AM
Ink on satin finish neck BigShred Tech: Setup, Repairs and Mods 3 06-21-2006 10:52 PM
Satin finish in rga121 jeffry J-Custom, USA Custom & Prestige Ibanez Guitars 11 02-10-2006 05:09 AM
FS: RG570 maple neck custom finish w/ case screamndemon69 Classified Ads: Guitars and Gear 4 01-17-2006 11:56 AM
Care of Satin Finishes Ibby J-Custom, USA Custom & Prestige Ibanez Guitars 1 11-29-2005 09:37 PM
