Tech: Setup, Repairs and Mods
Maximum edge-pro height adjustment
02-10-2007, 05:49 PM
scotte_za
Posts: 592 - iTrader: (
I want the 3 lowest (B, E, A) strings of my 1527 to be quite high, what's the highest level the edge 7 bridge can be adjusted to. I mean if I keep on raising the height of the action is my trem eventually gonna pop out or is there something in there that will stop me from adjusting it to it's limit?
Thanks
scotte_za
Find all posts by scotte_za
02-10-2007, 05:53 PM
scotte_za
Re: Maximum edge-pro height adjustment
Oh, and I assume the angle of the trem when it's not being manipulated by the trem-arm should be parallel to the guitar's body yes? Apologies for the stupid questions, I've never set up a guitar before and can't bear to leave it in the shop while my amp sits home unused, so I wanna learn to do it myself
scotte_za
02-10-2007, 07:12 PM
ryanb
Posts: 1,457 - iTrader: (
If you are talking about raising the action with the
trem studs
, yes they will eventually come all the way out of the anchors -- but the action will be ridiculously high before that happens. If you only raise the bass side a lot, you may run into problems with the trem hanging up. The individual saddles can be raised with shims if you want to raise only those strings without moving the others.
ryanb
Find all posts by ryanb
02-11-2007, 07:31 AM
scotte_za
excellente, thanks ^^
scotte_za
02-11-2007, 03:42 PM
scotte_za
mmm, now heres an interesting problem. I need to set the intonation, but I dont have the tool to do it (no cash at the moment) does anyone have a method for setting intonation without the tool (the one that holds what i believe are called the saddles in place)?
04:00 PM
scotte_za
02-11-2007, 04:26 PM
Dee
Posts: 8,514 - iTrader: (
Loosen the saddle screw, adjust, retighten, tune, repeat until you have it as close as you can get it using a tuner.
Dee
Find all posts by Dee
02-11-2007, 07:05 PM
ryanb
Well, for the Edge Pro, there is no tool anyway. So you get to do it the old way as Dee mentioned: loosen the string, move the saddle, retune, repeat.
You can also use Rich's method. Use a padded clamp to hold the trem bar down to the body. That takes the tension off the strings and lets you adjust the saddles without spending so much time winding tuners. Release the bar and recheck.
ryanb
trem studs
how to get string height on strat low
how to set up a edge 3?
is my edge trem bar in all the way
Edge mysteries solved!!......? - Answers to some common ques
Jason Stone
09:35 AM
Edge Pro uneven string height
jonny
03:18 PM
Broken height adjustment screw
~Viper~
10:51 AM
Edge pro bridge height difference
func
08:52 AM
Just a question... - about Tremolo Bridge Height Adjustment
armindo__dias
01:20 AM
03:32 AM
