Tech: Setup, Repairs and Mods
Might be a silly question about strings...
10-04-2008, 09:05 PM
nubeplayer
Posts: 3 - iTrader: (
Hey guys, apologies if this question has been asked before, but I couldn't find anything when I searched.
I'm a beginner guitar player, started about a month ago. I bought a really cheap electric guitar, but it doesn't sound that bad. But I'm not very familiar with the equipments and have not played around with different models to know what sounds good.
But my problem is, whenever I pluck a string, it makes my other string vibrate and created notes just as loud as the one I plucked. For example if I pluck the e string, the G and D string also make a sound. It's annoying because the other strings are so loud that it interferes with what I think the song I'm trying to play is suppose to sound like.
Is it normal for electric guitars to do this? Because I have not noticed this problem on my friend's acoustic guitar. Do I have a crappy guitar? Is there anything I should adjust at the bridge to prevent this? Or should I somehow learn to play the guitar so that I mute the other strings?
nubeplayer
Find all posts by nubeplayer
10-04-2008, 11:12 PM
elcid
Posts: 8,720 - iTrader: (
Re: Might be a silly question about strings...
Practice more and learn how to mute.
elcid
Find all posts by elcid
10-05-2008, 03:44 AM
Pursuit
Posts: 680 - iTrader: (
Sounds like a problem that lots of people have when they start on guitar. Sometimes, when you're beginning, you might actually slightly hit some other strings while trying to get just one (happend to me often when I started). You mentioned your friend's acoustic hasn't got this problem. That's probably because generally acoustic strings are spaced wider apart than electric strings. When I started, I used an acoustic, and didn't have a problem. When my first electric came along, I had to be very careful to not hit the other strings (because they were so much closer). Just be really careful and eventually you'll get more accurate. Of course, this is just my opinon, it might be something else.
Pursuit
Visit Pursuit's homepage!
Find all posts by Pursuit
10-05-2008, 04:52 AM
kotornut
Posts: 1,847 - iTrader: (
Yup, practicing and learning proper string muting techniques as you go along is the fix for it. Welcome to the never ending road of guitar learning. It's worth it and fun, but at times it's not easy and it gets annoying.
kotornut
Visit kotornut's homepage!
Find all posts by kotornut
10-05-2008, 11:34 AM
nubeplayer
Thanks for your help dudes, I guess I just have to practice more.
nubeplayer
10-05-2008, 11:51 AM
GuitarBizarre
Posts: 1,184 - iTrader: (
muting will certainly help, it comes with time.
I will say however, it doesnt sound like you're hitting the wrong strings or extra strings, as Pursuit was indicating. I think he may have overlooked the fact the strings that are vibrating are a string away from either of the e strings.
If nothing else, your guitar may simply be resonating a bit. Muting and learning to control unplayed strings is the key in any case.
GuitarBizarre
Find all posts by GuitarBizarre
10-05-2008, 11:54 AM
S-man
Posts: 1,757 - iTrader: (
It will come in time.... At least you are aware of the "problem".
S-man
Find all posts by S-man
10-05-2008, 01:18 PM
Ryan350DX
Posts: 179 - iTrader: (
I used to have the same problem when I first started, I used to ask Al McKenna (which goes to this forum now and then) how to mute and stuff because whenever he played it would sound so clean. Heres the tricks..
When playing the guitar you should always have the side of your hand on the strings. I go halfway on the bridge and half on the strings. And when plucking a string you let off it so it doesn't totally mute the string, but it keeps the other strings muted. I am a BIG Raker, pretty much every time I start a solo I rake, it adds alot of depth and feeling into the note. If you have any questions just ask.
Ryan350DX
Find all posts by Ryan350DX
which way should the strings go
what guitar strings do the pros use
what strings do you use for PRS
are ghs strings stiffer?
what kind of strings does korn use
Silly Tab question
superhairycamel
Guitar Lessons & Music Theory
08:28 AM
Silly question time
Ant1981
Gear and Equipment
06:11 AM
Maybe a Silly Question
fettouhi
03:18 PM
Possibly a silly question regarding vol/tone knobs on a DBK
Guitarlos2
06:16 PM
Silly question. Your input would be highly appreciated
SeanT
03:43 PM
02:47 AM
