Tech: Setup, Repairs and Mods
My Neck Hurts!
05-09-2007, 04:56 PM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
My Neck Hurts!
Yep the neck off of my 91' 570 has cracked. I plan on fixing it, but I have some issues I'm worried about and I'd like to get some opinions. First off it's cracked where it usually happens, by the 2 nut holes. The problem is that it extends to about half way between fret 1 and 2 all the way down to the fretboard on both sides. So I figure I'd remove the fretboard, finish the break (it's very close to completely broke anyway) and put it all back together and so on.
My worry is that using the method on project guitar with the steam and all, will it warp my neck? I took the finish off it once I got it so will this affect my neck? Thanks for any help, I hope to hear some opinions or answers soon, I'd like to start playing it again ASAP.
brothersnowgone
05-09-2007, 06:04 PM
Jaden
Posts: 2,464 - iTrader: (
Re: My Neck Hurts!
sounds like this:
http://www.ibanezrules.com/tech/setup/crack_neck.htm
personally, I would avoid the aggro of removing the fingerboard..
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
05-09-2007, 06:28 PM
Ayrton
Posts: 4,157 - iTrader: (
44
Re: My Neck Hurts!
If you can fill the crack with glue without having to remove the fretboard, then that is the way to go.
Ayrton
Find all posts by Ayrton
05-10-2007, 12:44 AM
brothersnowgone
Reviews: 7
Re: My Neck Hurts!
Been there, done that. The crack is too severe to get glue everywhere it needs to be anyway. The guy that fixed the crack originally did this and it cracked in the same spot sooo..... I'm decided on removing the fretboard, I just need to know is it going to cause my neck to warp? I also forgot to mention the fretboard is coming up from the nut to about the first fret.
brothersnowgone
05-10-2007, 12:47 AM
Moibanez
Posts: 466 - iTrader: (
Re: My Neck Hurts!
Just get a new neck online for about 150 bucks and your all fixed up. Order one tonight and you will be playing by Saturday....
Moibanez
Find all posts by Moibanez
05-10-2007, 01:01 AM
LonePhantom
Posts: 5,366 - iTrader: (
Reviews: 98
Re: My Neck Hurts!
Sounds like the glue used was not strong enough. Get some Titebond, that will do the job. You might also need to make some wood dowel pins to strengthen it if it's really bad. That's what I've had done to mine.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
05-10-2007, 02:06 AM
David McCarroll
Posts: 2,049 - iTrader: (
Re: My Neck Hurts!
LonePhantom
+ 1 on Lone Phantom - if you are going to remove the fretboard, you stand a reasonably good chance of totally destroying the neck in the process, if the headstock is still attached, don't finish the job - just follow Rich's tutorial on fixing a cracked headstock and clamp it well - Titebond, or Titebond 2 are physically stronger than wood, so if the job is done correctly, you shouldn't have an issue again.
If you have even the slightest doubts as to your abilities, I really strongly suggest you get a good luthier to do the job for you, it's not really difficult, but it's also easy to screw it up.
David McCarroll
Find all posts by David McCarroll
05-10-2007, 02:14 PM
ken_r152
Posts: 535 - iTrader: (
Re: My Neck Hurts!
I have a guitar that someone gave to me where the headstock was snapped almost clean off. It was an RG270. It was fixed professionally, and the luthier used 3 brass screws as well as glue. The screws are countersunk into the wood. The guitar plays quite nicely, actually. And the back of the neck is so smooth that I rarely notice that there are three screws there under the first fret.
ken_r152
Find all posts by ken_r152
05-10-2007, 06:55 PM
brothersnowgone
Reviews: 7
Re: My Neck Hurts!
David McCarroll
I know titebond was what was used originally and it's the only glue I use. I'm not doubting my abilities at all, just the fact that it IS unfinished, that's my only worry (other than warping, I have no worries about removing the fretboard due to a lack of skills). I know the crack is all but completely through the neck, I can clearly see that by putting minimal pressure on the headstock to see the break and I know I won't be able to get glue in every crevise. And the fact that the fretboard is already lifting is the only reason I really want to take it off and finish it that way. Also the crack is in the nut holes aswell, at the very bottom. I don't see being able to get glue in there good enough with a slice of plastic...
After a closer look, it looks like someone tried to glue down the fretboard once before (probably the same person who gluedthe neck crack), and yet another reason for me to remove it. I need to get a thin film of glue off from bottom of the board where it's lifting from the "previous fix".
04:44 AM
brothersnowgone
david mccarroll
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
Damaged Neck Screw Holes On My Body
Eddie_V_H
04:03 AM
Jap Wizard neck on a Korean RG??
LonePhantom
01:01 AM
Hands of ACID on a jem7vwh neck
ZaPeRoN
08:16 AM
What is the best way to drill neck holes in new body.....
SilverSurfer2
06:41 PM
Changing Vine inlay colors - things that make you go hmmmmmm
tomizm
34
04-13-2001
03:14 PM
05:51 PM
