Old 05-23-2007, 03:28 AM
mushroomwick  is offline
Posts: 11  -  iTrader: (0)
my solution for a perfect shim
I discovered a bunch of antimony leaflets in my fathers stuff he left to me. I decided to try using them as shims in my guitars. I have had excellent results. They are metal and slightly stiffer than gold leaflets. The result is that when used in a nut or neck shim they offer a tight fit and seems to even improve sustain. I will mention though, Antimony is a very poisonous metal. I would not recommend handling it anymore than nessesary with your bare hands. However, once its in the pocket, it won't be in contact with you any longer. Off the wall thing to find laying around the house isn't it? My father babbled with alchemy. If you know much about it , it explains all.
Old 05-23-2007, 07:59 AM
madpickin03  is offline
Posts: 531  -  iTrader: (1)
Re: my solution for a perfect shim
Eric Johnson wannabe....
eric johnson, neck shim
Nut shim material? waylay00 Tech: Setup, Repairs and Mods 7 10-18-2008 01:31 AM
Neck Shim Materials Gex Tech: Setup, Repairs and Mods 7 07-27-2006 02:21 PM
Do I need a neck shim? giannifive Tech: Setup, Repairs and Mods 8 02-10-2005 04:39 PM
A Perfect Circle- Denver,CO 03/20/04 vaijem777 Tours: Going to Shows 0 03-21-2004 11:32 AM
How many times can you shim the neck? Triangle Tech: Setup, Repairs and Mods 16 07-30-2002 12:38 PM
