Old 08-04-2007, 10:10 PM
Big Red  is offline
Posts: 328  -  iTrader: (0)
My Strings Are Going SHARP After A String Change!?!?
Hi Guys,
I have a small problem with my Edge III tremolo-equipped RG320FM. I haven't used it for about 4 months, and then last week I went to change the strings (I'm selling the guitar soon). When I was changing strings I noticed that the bridge had-little-to-no room to go sharp (e.g. semi-tone at best). So, I changed the strings (and let them stretch for a few days), and re-adjusted everything so the the trem-angle is neutral, string action is factory height, neck relief, etc, etc. But all of the strings are going sharp, as if the bridge wants to rest against the guitar's body. If I keep loosing the strings in order to tune correctly, I'm afraid then that what will happen. Now what?
Thanks
Old 08-04-2007, 10:31 PM
Gusfmm  is offline
Posts: 280  -  iTrader: (6)
Re: My Strings Are Going SHARP After A String Change!?!?
Tried loosing the trem anchor screws in the trem cavity a bit?
Gus.
Old 08-08-2007, 11:59 AM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
You "changed the strings and let them stretch for a few days"? You also mentioned that you readjusted everything so the trem angle is neutral. Did you replace all strings at the same time or did you replace the strings one at a time? Anytime you replace strings YOU should be the one who does the stretching, and the guitar.
How come the trem has "little to no room to go sharp"? can you post some pics of what you're talking about?
I haven't used my trs-equipped yamaha for while and the guitar is still in tune since the last time I changed the strings on it which was at least 3 months ago.
Jimmy
Old 08-08-2007, 12:03 PM
jemaholic  is offline
Posts: 2,806  -  iTrader: (14)
Images: 13
Are the new strings the same gauge as the old ones?????
Old 08-10-2007, 12:04 AM
JeffWiredBeck24  is offline
Posts: 181  -  iTrader: (1)
I seem to be having the same problem with my Original Edge Trem, whenever I fine tune, the strings are sharp and I have to keep going up.
My RG came stocked with 9s and I currently have 9.5s on it.
edge iii trem, edge trem, neck relief
Best place to buy bulk strings?? NickCormier Tech: Setup, Repairs and Mods 1 05-25-2007 02:09 AM
strings for my new 7 string baritone (1077xl) skattabrain Other 7-string Guitars 5 11-06-2004 03:17 PM
High E string fine tuner will not go sharp (Help please) mikeyCOA JS (Satriani Model) Ibanez Guitars 4 10-17-2004 01:57 PM
de-tuned 7 string - what guage strings? Joshka Other 7-string Guitars 0 02-24-2004 05:18 AM
Known history of Guitar.. (lots of people have it wrong) - a vwall Other 6-string Guitars (non-Ibanez brand) 10 05-09-2001 02:20 AM
