Old 07-02-2008, 05:48 AM
superhairycamel  is offline
Posts: 338  -  iTrader: (0)
nasty noise from prestige rg (that high fret warbling noise that you DONT want)
hi
i have a friend's prestige 2550 (i think its a 2550, it has a pickguard and small dot inlays) at my house to set up for him and im having a strange problem.
you know that sound you get when the pickup/s are too close to the strings, it makes that warbling sound (wawawawawawa) particularly on higher frets on distortion on string G and B but also on others, it just seems to show more on these strings.
I tried lowering the pickups (to their minimum) and still it sounds as disgusting as ever!
The guitar is not perfectly intonated, could this have something to do with it?
im not sure what to do about, i think i can even hear it unamplified (am i going crazy?)
Old 07-02-2008, 05:57 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
Re: nasty noise from prestige rg (that high fret warbling noise that you DONT want)
If you've eliminated pickup height then check the intonation. You'd be surprised the difference it makes when a guitar is properly intonated. I suspect you have beats (http://en.wikipedia.org/wiki/Beat_(acoustics)) between the fretted note and one of the harmonics (possibly on an adjacent string).
Jim
Old 07-02-2008, 06:34 AM
scotte_za  is offline
Posts: 592  -  iTrader: (0)
I had this problem with my cheap Epiphone SG, intonating it didnt help.
I put new strings on it and re-intonated and the problem just went away.
Old 07-02-2008, 06:41 AM
i have to set it up anyway so ill change strings, intonate and see if theres still a problem PS its not BEATS because its only one string at a time.
thanks for you rquick responses!
Old 07-02-2008, 07:48 AM
Ibateur  is offline
Posts: 2,951  -  iTrader: (3)
also reduce anything between guitar and amp. Remove all pedals etc. Happens on all the pickups?
Old 07-02-2008, 02:49 PM
GAZ  is offline
Posts: 442  -  iTrader: (0)
Sounds like very old,dirty and worn strings to me !!
Old 07-02-2008, 03:26 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Same to me...
Old 07-02-2008, 11:49 PM
rvai  is offline
Posts: 458  -  iTrader: (0)
+1, I once set up a friend´s warlock which sounded just like you said in the last frets of the high strings, I just changed the strings and there was no more weird buzzing, I just intonated and that was it
Old 07-03-2008, 07:27 AM
gotta wait on the setup because i thought he said 9 - 46, but i put on a set of those suckers and whoaha the bridge went way up, so im trying to get onto him to ask if he want me to set up in 9 - 46 or maybe 9 - 42 like i guess he was using
Old 07-04-2008, 12:57 AM
rvai  is offline
maybe you only have to stretch the strings so the bridge goes back to neutral? I´m almost shure that a setup with new strings will solve the problem
Old 07-04-2008, 09:00 AM
so is all set up, playing nice and intonated (took ages) and the problem of the noise has eased but is still not nice and def worse than my 570 which i have a tonezone in bridge...hhhhmnnnn.....
is it perhaps electronics?
pickups are still far from strings.
dot inlay, high strings, pickup height
Help, action high at 5th fret, low at 19th fret Rachmaninoff Tech: Setup, Repairs and Mods 3 06-06-2008 12:03 PM
JS 1200...warbling when pickign hard, trem noise etc... KissMyAxe JS (Satriani Model) Ibanez Guitars 6 02-19-2006 09:45 PM
Noise gate for rack: need high quality, reasonable priced SilverSurfer2 Gear and Equipment 3 01-09-2004 03:28 PM
noise - ringing noise chip james JEM and Universe Guitars 6 01-15-2001 08:08 PM
