Old 06-09-2009, 01:36 PM
manticus  is offline
Posts: 116  -  iTrader: (1)
Neck and scale length question
Maybe you all can help me out with this...
I just bought a Jackson DXMGT-SP Hardtail body off the auction site. I know it's a 24 fret, 25.5" scale length guitar. I have a neck that is a 22 fret 25.5" scale length that I love. Can I use it? The neck pocket should be the right size (2.25"). Just wondering if the length of the should be right with 2 less frets? Bueller?
Thanks in advance for any help!
-Andy
Old 06-09-2009, 02:07 PM
GuitarBizarre  is offline
Posts: 1,184  -  iTrader: (0)
Re: Neck and scale length question
no, it won't fit. the neck pocket will be routed too close to the bridge for it to intonate correctly.
Unless of course your 24 fret neck is actually a 22 with a fretboard overhang to give you 23 and 24, then it might be possible, but thats probably not the case on your guitar.
Old 06-09-2009, 02:52 PM
manticus  is offline
Would it be possible to shim it, maybe? Or do you think that might make it to unstable?
Old 06-09-2009, 02:56 PM
shimming it would take it completely out of alignment with the neck bolt holes.
Old 06-09-2009, 03:11 PM
manticus  is offline
True, but would re-drilling them be a terrible thing?
Old 06-09-2009, 03:29 PM
Well you would be moving the mounting holes closer to the EDGE of your neck pocket, as opposed to further in. even if you dowelled and redrilled, I'd say you'd probably end up with only a few mm of wood at MOST on the edge of the bolts. It would likely be a very very weak neck joint, and the first time it got a shock it would probably be enough for the bolts to shear through the last of the wood holding them in place.
Not to mention resonance and everything else would suffer accordingly.
My 2 cents - give up on using that neck. If you really want to have a guitar with THAT neck profile, and can't stand the idea of anything else, I suggest you look at custom work.
Old 06-09-2009, 03:32 PM
manticus  is offline
Probably true, but it was worth a shot...
Old 06-09-2009, 04:41 PM
ColinMmmmm  is offline
Posts: 1,068  -  iTrader: (1)
You could redrill the bridge mouting hole an inch further back or whatever. Then redrill the through-body ferrules. Then you might be able to intonate it properly.
Or you could just swap it for a 22 fret guitar.
Old 06-09-2009, 10:42 PM
manticus  is offline
I thought about maybe fashioning an extension to the end of the neck. Taking off some of the wood under the end that mounts to the body and joining an extended piece that would cover the extra distance. If joined right, it would be very strong.
If nothing else, it would be an interesting experiment...
Old 06-09-2009, 11:51 PM
and on that extension you could put two extra frets . . .
Old 06-11-2009, 01:21 PM
manticus  is offline
I got the body last night and mated it to the neck for measurement. It seems that the 24 fret Jackson neck has a fingerboard extension past the pocket. Not quite enough, but I'm only 1/4" off now. I'm sure I can find a suitable solution. Woohoo!
build, dxmgt, jackson, neck, scale length
scale length question Torrance Other Ibanez Guitars (including Premiums) 3 09-28-2006 12:52 PM
Building/Scale Length question.. ibanezrocker61 Other 7-string Guitars 11 09-14-2005 12:50 AM
longer neck scale length rbjammin Other 7-string Guitars 14 06-25-2004 07:40 PM
Ibanez AF 207 7 string jazzer-24.7"scale?? - Scale length is speedball Comments to Ibanez 12 01-12-2003 10:44 PM
How do you like the XL scale length? Zeek Other 7-string Guitars 22 11-13-2002 12:02 PM
