Tech: Setup, Repairs and Mods
neck binding
04-03-2001, 06:26 AM
cowcowcow
Posts: 289 - iTrader: (
neck binding
Will a bound neck wider than a non bound neck?
When Ibanez craft the neck
they add the binding to the neck or they cut the edge of the neck and then add the binding to it so the width of them would be the same?
cowcowcow
Find all posts by cowcowcow
04-03-2001, 11:17 AM
darren wilson
Posts: 4,190 - iTrader: (
neck binding
Binding is installed by routing a channel along the edge of the neck/headstock/body, then gluing in the binding. It shouldn't be any wider than an un-bound neck... unless it were designed that way.
darren wilson
04-03-2001, 11:53 AM
ChrisReedSmith
Posts: 523 - iTrader: (
neck binding
yea what he said. and FYI, the binding is attached to the frets so if you want to install it yourself your going to have to lift the frets out and then reinstall them.
ChrisReedSmith
Find all posts by ChrisReedSmith
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
06:15 PM
