Tech: Setup, Repairs and Mods
neck keeps moving side to side
08-06-2006, 05:16 AM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
I'm setting a guitar for a friend of mine in a band and he's been having this problem with the neck sliding from the bass side to the treble and as you could imagine it's messing up his tuning. Any suggestions on how to remedy it short of glueing the neck in place?
brothersnowgone
08-06-2006, 08:14 AM
Apple_Horn
Posts: 208 - iTrader: (
Re: neck keeps moving side to side
What kind of guitar is it ?
Apple_Horn
Find all posts by Apple_Horn
08-06-2006, 08:45 AM
horstausmforst
Posts: 663 - iTrader: (
Had the same problem on an RG. First, check for burrs/saw dust in the neck pocket and remove them. If everything seems fine, put a shim on one side of the neck pocket (not under the neck, but besides the neck), that should help wonders.
horstausmforst
Find all posts by horstausmforst
08-06-2006, 11:20 AM
Racerx2k
Posts: 1,076 - iTrader: (
If you have issues with necks sliding in pockets, try ading a piece of metal window screen between the neck and pocket. The metal will bite in to both surfaces, eliminating the shift. This is even reccomended by Dan Erelwine, in his books.
Racerx2k
Find all posts by Racerx2k
08-06-2006, 03:25 PM
brothersnowgone
Reviews: 7
Thanks guys, I'll try that trick Racerx2k. It's just a cheap LTD M-107 Apple horn, I played it many times before and it's actually pretty nice for how low level it is. Another problem I'm having while setting it up is the
neck screws
take forever to fully tighten, and when they get close to being all the way in they get much harder to tighten and I don't want to strip out the neck holes, but I know the neck isn't fully down at this point. So far I've filled in 2 of the holes to give them better grip and it seemed to work, I'll try it on the last 2 holes to see if it takes care of the problem, thanks again for the help so far...
brothersnowgone
08-07-2006, 02:40 AM
sniperfrommars1
Posts: 3,302 - iTrader: (
brothersnowgone
Thanks guys, I'll try that trick Racerx2k. It's just a cheap LTD M-107 Apple horn, I played it many times before and it's actually pretty nice for how low level it is. Another problem I'm having while setting it up is the neck screws take forever to fully tighten, and when they get close to being all the way in they get much harder to tighten and I don't want to strip out the neck holes, but I know the neck isn't fully down at this point. So far I've filled in 2 of the holes to give them better grip and it seemed to work, I'll try it on the last 2 holes to see if it takes care of the problem, thanks again for the help so far...
Frankfalbo spoke about this issue once. Your screws tightening up like that lead me to beleive, that the screws are binding against the body. They really shouldnt be doing this, and you may solve the issue altogether by widening the screw holes (on the body itself) . Make sure you read what i said carefully, and try the other methods first though.
sniperfrommars1
Find all posts by sniperfrommars1
08-07-2006, 05:22 AM
brothersnowgone
Reviews: 7
I'll check that, see if I can't rule it out, hopefully. I'll get back to you guys when i have the patience to do this lol.
brothersnowgone
neck screws
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
FS RG550 body & neck, RG570 neck & misc
screamndemon69
01:58 PM
Do I need a neck shim?
giannifive
04:39 PM
Removing the Neck on a 7DBK!!!
Chipiem
04:53 AM
I refinished my neck - Bare wood & reshaped Les Paul 7-strin
revsharp777
04:40 PM
Screwed up pickup - Neck humbuker won't work
RG Guy
07:37 PM
08:18 PM
