Tech: Setup, Repairs and Mods
Neck replacement question.
10-28-2004, 05:24 PM
JN777
Posts: 184 - iTrader: (
i have a 24 fret ibanez rg570 can i switch the neck with a 22 fret S470 neck?
JN777
Find all posts by JN777
10-30-2004, 11:51 AM
Elysian
Posts: 324 - iTrader: (
Re: Neck replacement question.
JN777
if its the same scale, sure... but why?
Elysian
Find all posts by Elysian
10-31-2004, 12:54 AM
JN777
yes is the same scale.
Well just wondering cuz the rg570 neck is signed on the back of the headstock by
paul gilbert
, and the sign is fading so that why.
But maybe ill use the s neck on a custom body. who knows
Thanks for the info.
JN777
10-31-2004, 02:13 PM
sindlei
Posts: 61 - iTrader: (
the neck pocket might be too big on the rg to accept an s neck.
sindlei
Find all posts by sindlei
10-31-2004, 03:19 PM
rory
Posts: 102 - iTrader: (
I highly doubt the swap would work. I'm guessing that the S470 neck has the AANJ heel. The only way the swap would work is if you had the older RG with the block heel and fretboard overhang, and a non-AANJ S neck, and you would still be left with that ugly space where the overhang would sit.
Your best bets would be to either clear over the sig on your headstock (even clear nail polish would protect it), or to get a neck to match...you can find them on eBay quite readily.
rory
Find all posts by rory
10-31-2004, 06:42 PM
Elysian
rory
or if he has a newer RG570 with AANJ. i don't think the heel would be any bigger or smaller on the S neck than the 570 neck.
Elysian
10-31-2004, 11:16 PM
toshiro
Posts: 1,811 - iTrader: (
Elysian
The bridge would be in the wrong place if you put an aanj 24 fret neck on a body designed for a 22 fret neck, or visa-versa.
In other-words neither will intonate correctly. The old heel 24 neck will go on a 22 fret body, but you'd have to ditch the
neck pickup
. Like-wise an old heel 22 fret neck will go on an old heel 24
fret guitar
and work.
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
11-01-2004, 01:30 AM
JN777
Thanks everybody, seems a little difficult to swap, maybe ill just build a new body for the s neck.
Does someone have an s pocketsize measurements????
JN777
11-01-2004, 03:28 AM
pinto79
Posts: 371 - iTrader: (
JN777
You do, just measure the end of the neck... or measure the pocket in the S body you have...
pinto79
Find all posts by pinto79
11-01-2004, 08:59 AM
Ibateur
Posts: 2,947 - iTrader: (
Why don't you just spray a few clear coats on the signature then?
That's what I would do.
Ibateur
Find all posts by Ibateur
11-01-2004, 12:26 PM
JN777
maybe, is it safe to use an spray can finish over the sign???
By the way here is the new body for the S neck.
JN777
clear coat
fret guitar
fret neck
neck pickup
paul gilbert
replacement for ibanez lo trs?
parker are they neck thru
edge pro stud replacement?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
10:51 PM
