Tech: Setup, Repairs and Mods
Need a neck - where to get?
09-17-2002, 08:59 AM
wbuckley
Posts: 4 - iTrader: (
One of my favorite Wizard (1) necks - an original year issue - has given up the ghost and broken for the last time. I need a replacement, but would prefer custom aftermarket over the "buy one on eBay" route (lest you get someone elses compound warp nightmare with a bad fret scale!).
Problem is, I cannot locate anyone online building custom Wizard style necks! Any recommendations from the good folks at Jemsite???
Thanks in advance,
/Bill B.
wbuckley
Find all posts by wbuckley
09-17-2002, 10:32 AM
darren wilson
Posts: 4,190 - iTrader: (
I bought a
Carvin Bolt
neck, and i think it's great... you can get semi-custom options (mine is maple/ebony with no face dots), and they've got great fretwork and awesome feel. Carvin also builds them with two graphite rods in channels under the fretboard, so it's probably also a very stable neck in the long run. The only drawback is they're only available in 22 fret versions. If you want a 24-
fret neck
, you'll likely have to go to Warmoth (who have an "Ibanez" profile) or get one built by hand.
darren wilson
09-17-2002, 01:48 PM
JESTER700
Posts: 2,234 - iTrader: (
Another big vote for the Carvin. VERY nice. It's thicker (20mm at 1st fret), so get it without finish on it and sand 'er down a little. No contest, it's the best bang for the buck out there.
JESTER700
Find all posts by JESTER700
09-17-2002, 01:53 PM
EKG
Posts: 2,280 - iTrader: (
Carvin doeas make a great neck! BUT, the 6 string versions are 25" scale. Warmoth generally does Strat replacement type necks and mostly for a Fender neck pocket. I seem to remember LIPE on the internet making necks?
EKG
Visit EKG's homepage!
Find all posts by EKG
09-17-2002, 09:33 PM
CrossingStar
Posts: 1,046 - iTrader: (
If it's the original square pocket/heel on your Ibanez a Warmoth will work, they have 24 fret extension boards and a Wizard-ish profile, though it's really somewhere in between a Wizard and Wizard II. I've put my
Warmoth neck
into an old RG550 pocket to check for fit and it goes right in, no problem.
Also
Custom Guitar Wares
CrossingStar
Find all posts by CrossingStar
09-17-2002, 09:58 PM
darren wilson
Eddie Kolesar
Incorrect.
Their neck-thru guitars are 25" scale. The Bolt guitars and replacement necks are 25.5".
http://www.carvin.com/cgi-bin/Isearc...OLT&P1=GTR
darren wilson
09-17-2002, 10:46 PM
JESTER700
In fact, the Carvin fits an Ibanez Radius pocket perfectly (as mine does). If you go this route, ask for "no drilled holes", as the Carvin bolt pattern is different from any Ibanez.
JESTER700
09-18-2002, 12:17 PM
EKG
Yes, the 22
fret necks
are 25-1/2", but the 24 fret necks (replacement) are 25". I asked if they could make a 25-1/2" 24 fret neck and they replied with they are not geared up for that.
EKG
09-18-2002, 02:41 PM
JESTER700
I thought the 24s were only
neck thru
- you'd need to cut a lot of maple off to make a strat size bolt replacement, right?
Too bad they DON'T make a 22 fret 25.5"
neck thru body
, Eddie - I'd be askin' you for some JS shaped wings!
JESTER700
09-18-2002, 02:44 PM
mike777
Posts: 656 - iTrader: (
Actually, I believe you can actually buy an
Ibanez neck
if you'd like but you have to send the original back. I'd double-check this.
Mike 777 Haug
mike777
Find all posts by mike777
09-18-2002, 03:11 PM
EKG
Mike777, I think you are correct! Why didn't I think of that?
EKG
09-18-2002, 04:07 PM
RSVampire
Posts: 1,813 - iTrader: (
WOW lot's of posts here for Carvin necks. Dude if you wanna get your Wizard neck back go to
www.warmoth.com
they make
custom necks
and bodies. They have necks shaped like a Wizard and Strat neck and such. So check them out. Not saying Carvin sucks...just saying they might give you more of what you want than Carvin will.
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
10-06-2002, 03:51 PM
PerKr
Posts: 151 - iTrader: (
Xing Cztarre
If it's the original square pocket/heel on your Ibanez a Warmoth will work, they have 24 fret extension boards and a Wizard-ish profile, though it's really somewhere in between a Wizard and Wizard II. I've put my Warmoth neck into an old RG550 pocket to check for fit and it goes right in, no problem.
Also
Custom Guitar
Wares.
are you sure about this? every time I asked about this people have told me that the warmoth necks will fit the pocket but not intonate correctly because the length of the actual neck isnīt the same as on the old Ibanez JEM/RG necks?
PerKr
Find all posts by PerKr
10-06-2002, 04:51 PM
dcord
Posts: 1,077 - iTrader: (
PerKr
Xing Cztarre
Also Custom Guitar Wares.
Original RG and JEM necks (in fact nearly all Ibanez pre-aanj bolt-ons) are built to the "Fender" spec, meaning they are 25.5" scale and will accept any guitar neck built to fit a Fender. The rules change a bit when you're getting a neck built for your AANJ guitar.
Warmoth necks are built to the "Fender" spec as well. ALL of them, unless you get a 24.75" scale neck, or they specifically state differently. This applies to their LP models as well.
You can get a neck from Ibanez, but it costs an arm and a leg and you are required to send your old neck in. Good luck!
~d~
dcord
Find all posts by dcord
10-07-2002, 12:42 PM
PerKr
this would mean that I could make a body using the JEM777 blueprints and just get a warmoth neck... I like it
thanks. I think Iīll double-check though, just to make sure
PerKr
carvin bolt
chrome jem
custom guitar
custom guitar wares
custom necks
fret neck
fret necks
ibanez jem
ibanez neck
jem neck
neck thru
neck thru body
warmoth neck
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
03:14 PM
